Question about Dewalt 18 Volt Compact Drill Kit
Cannot engage hammer action
Hi, i ve got a dewalt dc925 XRP drill, the drill works ok but cannot turn the dial to the hammer action. it stops at the 21 setting and will not turn any further.Pls can you help
  • 2 more comments
  • fredsam0512 Jun 08, 2008
    Cheers Hammer Drill, done what you said working great now.
  • Monk1932 Jul 07, 2008
    Hammer Drill,
    I am currently having the same problem with my dewalt (DC925), and I used the solution mentioned in another post of yours...:
    ...and I was successful, but as you mentioned it was only temporary and your current solution has not worked for me either. It appears that the adjustment ring has a "ramp" on it and as you turn the ring from lower to higher the pin is pushed into the transmission further increasing the torque. (Does that sound correct?) If it is correct, it appears that the ramp has chipped or broken right between the 21 and 22 settings. I disassembled and adjusted the ring so that I can use the 22, drill, and hammer drill settings (Which is my primary area of need) but if I adjust to 21 or below I am stuck in the 1 to 21 range. I would like to fix this problem once and for all, how would I go about doing this.
    Thanks for all your help,
    Also attempted the solution mentioned in this post, with no success.
  • Anonymous Mar 17, 2014
    My deWalt DC725 hammer action will not turn off. I can change speeds, direction etc but the hammer action stays on.
  • 313 Answers
The problem is the metal part of the clutch that meets the pin from the transmission. remove the 4 screw from the clutch & check if the the inside of the clutch & the trans pin meets. all you can do is to push back the metal parts of the clutch setting.
Posted on Jun 08, 2008
It is very hard to turn the adjustable ring that switches from drill to hammer grill
Hi my 925 has had same problem right out the box it must be an allignment thing a find a tap with the old hammer sorts it out
Sep 15, 2012 | Dewalt DC925 Cordless Drill
Can't engage drill or hammer settings on de walt dc 925 xrp
Try turning the ring to 2 or 3 and run the drill holding the chuck so the clutch slips then try turning it to drill setting. Also try to do it in different speed settings. If not it sounds like a fault in the gear module. It might just be a metal clip just under the clip in side. Undo the 4 screws holding the gearbox onto the housing and carefully remove it, you might see the fault or loads of dirt that needs cleaning. Go to for a drawing.
Jun 01, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
When I pull the trigger on my Dewalt dc925 xrp hammer drill it's working for a bit then stopping and starting
it sounds like you have a problem with the switch or battery. Try cleaning the battery contacts first and then remove the battery and look into the tool and see if the switch contacts are bent not allowing battery to seat firmly. If that is OK then I would think that you need a new switch. MAKE note of how you remove it because it is polarity sensitive. Let me know if you need more assistance.
Jan 09, 2012 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How to--- chuck removal DC925 drill DeWalt
Open the chuck fully. Inside the center bottom of the chuck you will normally find a reverse threaded lock screw that you must first remove. If it is hard to loosen, you may need to heat it with a micro torch or a heat gun to make the thread lock compound slip. Then fasten the smaller end of an allen key firmly into the jaws of the chuck. Engage the low gear. Then hit the longer end rapidly with a hammer to unscrew the chuck by rotating it anti clockwise.
Sep 05, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Drill works fine but wont engage hammer. the torque ring goes from 1 to 21 ok but i cant engage the drill or hammer setting
On my DW988 the ring would go past 21 a couple of clicks to a symbol that looks like a yellow T and that would be hammer mode when I press down to drill.
Nov 18, 2009 | Dewalt DC925 Cordless Drill
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
I have a dc925 xrp hammer drill which i got second hand and the clutch does not work at any of lower torque settings needed for screwing is this likely to be an easy fix?
Go to and download a breakdown for this tool, most of the parts are component parts that you replace as an assembly.
Oct 11, 2009 | Dewalt 18 Volt Compact Drill Kit
All i need is the schematic for a dewalt hammer drill cordless 18 volt xrp model # dc925 serial # 991347
go to and in the middle of the page type in your model number and you can download a breakdown for this tool. If I have answered your request would you please rate this response accordingly.
Oct 09, 2009 | Dewalt Drills
How to select hammer action
turn the torque adjustment collar until the hammer is selected (there is a picture of a hammer instead of a number there)
Oct 01, 2009 | Dewalt DC925 Cordless Drill
Dewalt 18V XRP Hammer drill, stops on torque in drillpositio
The brushes might need to be replaced. You can find them on Ebay and are easily to replace.
Aug 01, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Dewalt 18 Volt Compact Drill Kit Logo
539 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
