Question about Car Audio & Video
Hi, I have a VX 2001 Commodore with a Eurovox AM FM radio/CD player. I had to replace the battery so now the radio will not go, the vehicle is second hand so don't have the manual with any codes needed to get it going again. I have tried 1111 which does get the radio going for about 5 mins but the display keep flashing then turns itself off. Any suggestions???
SOURCE:
  • 199 Answers
SOURCE: VT Commodore security coded head units
Call Holden with the VIN# on the car, and they will give you the correct code.
Posted on Mar 10, 2008
  • 185 Answers
SOURCE: Hi - I changed the
really it shoud be on the top of the raido when u take it out look on top of the radio for a 4 diget code
Posted on Apr 05, 2008
  • 71 Answers
SOURCE: Replaced radio with one from same model year. Displays Err 01.
this generally means the laser is either dirty or the cd player is shot, err 01 is a disc reading problem. Try cleaning lens with cleaning disc first if this does not help i would replace the unit with another. i would recommend replacing it with a cheap aftermarket stereo.
Posted on Nov 27, 2008
SOURCE: radio code help
last 4 numbers of vin
Posted on Dec 19, 2008
ILikeBMW
  • 117 Answers
SOURCE: Radio code not working for 6000 cd rds eon
Hello There.
There are many websites that offer an unlocking service for a few £/$ . here is one that I found.
http://www.radio-code.co.uk/ford-radio-codes.html
Hope this helps.
If my answer has helped you, please rate me on Fixya.
Many Thanks
ILikeBMW
Posted on Mar 07, 2009
My battery went flat and I jump started my car (Holden VT) now my stereo is locked. Dose anybody know how to unlock it. It's a eurovox radio unit.
Samantha, You need the VIN and the radio serial number. Take those into a Holden dealer to get the radio code and programming instructions from the dealer. They may want a small fee for the #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/131983-vt-stock-radio-cassette-player-security-code.html
Radio Security code Street Commodores Online Forum
Go Technologies Eurovox FAQs
Aug 26, 2016 | Holden Cars & Trucks
Why is my eurovox radio flashing then shuts off in 4 minutes
sounds as though the radio requires the radio security code to be entered. This is often supplied with the manual / handbook - have a look for this first and then enter it. The radio code is often required if the car loses power / flat battery, removed battery, fuse etc. If not you may need the serial number of the unit (may have to remove the head unit) and possibly the VIN vehicle identification number of the car and contact Volkswagen. I did find this site but it is in Oz so I doubt it will be applicable but you never know...http://www.go-tech.com.au/faqs.html
Oct 07, 2014 | Volkswagen 2001 Eurovan Radio / CD Player...
How to use eurovox pin in a vx commodore?
Radio P.I.N. (Personal Identification Number)
Your PIN. must be entered if the battery is disconnected. The P.I.N. is shown on the
security card that was originally in the glovebox of the new car. Please keep the card in
a safe but accessible place (not in your car), as this safety feature is provided as a theft
deterrent.
To enter the P.l.N.:
•turn ignition to accessories and turn radio on ("1" or "CdE 1" appears),
•press the radio buttons in your P.I.N. order,
•the radio will shortly begin to play.
If an incorrect P.I.N. is entered the number "2" or "CdE 2" appears on the display.
Following three incorrect P.l.N.s the display shows" - - - ", and the radio must remain
connected to power for approx. one hour before the correct P.I.N. can be entered.
Therefore, if your car repair requires battery disconnection you may wish to provide the
servicing dealer with your PIN.
If the P.I.N. number is XXXX, contact your Holden Dealer. He will require proof of
ownership and the Vehicle Identification Number shown on the inside front cover of this
handbook. There may be a nominal charge for this service.
May 31, 2014 | Blaupunkt PCA250 Car Audio Amplifier
Need a pin number for my eurovox radio from a vx commodore
It's specific to the car check owners manual or go to vw shop to get reset
Apr 02, 2014 | Cars & Trucks
Hi I purchased a Citroen Berlingo 2005 second hand.Radio needs cod, I don't have. Radio is a eurovox 3385 model no.MOD3385CIT1 serial no. 46000825.4. can anyone help.
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Citroen service centre and get them to enter this code for you.
Sep 23, 2012 | Car Audio & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
I need help!
HI THERE I JUST PURCHASED EUROVOX RADIO WITH 10 CD STACKER FROM EBAY BUT THEY NEVER SUPPLIED ME THE CODE TO ACTIVATE THE UNIT BOUGHT IT OF COMMODORE WRECKER IN SUNSHINE VICTORIA CAN YOU HELP PLEASE
Aug 01, 2008 | Audiovox SP11CDP 10-Disc CD Changer
Car Audio & Video Logo
275 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
