Question about LG Vu CU920 Cellular Phone
I was in heavy rain and my phone got wet. I took the battery out and let everything dry. everything works except for touch screen
  • 282 Answers
The digitizer maybe bad. You may want to leave it out without the battery in. use a blow dryer but do not heat it up it will crack the screen. If that doesn't dry the screen out then the digitizer will have to be replaced. hope this helps.
Posted on Oct 23, 2010
SOURCE:
I got my phone wet while travelling abroad so I took out the battery etc and let them dry for a while. When I put them back in the phone seemed fine but the next morning the battery was completely broken,...
You cant try this...get a bowl of dry rice, put the phone in and cover it up, leave the phone in for 48 hrs. Dont touch it.
Sounds like there is remaining moisture. if this doesnt resolve the issue you will need a new phone
Mar 04, 2011 | Cell Phones
Xda o2 atom
The video control IC might have gone due to short circuit. So you take to the appropriate service station to get it fixed.
Jul 21, 2009 | O2 Xda Atom Exec Smartphone
Phone got wet & works fine but says network error
Cell phones do not recover gracefully from getting wet internally. The electronics were not made to get wet.
You would be better served to get a new phone. Getting a cell phone wet is almost alway death to the electronics, even if the phone is dried out completely, The problems caused by the damp electronics will cause strange and intermittent problems.
Jul 14, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Broken screen on lg dare Broken touch screen. can it be replaced? got my phone wet for a second. dried it off. everything works, but my touch screen will not respond on the left side of the phone. water...
ive had a similar problem... but what i did is i looked at what the insurance does cover... since it doesnt cover water damage.. defect the phone in some way that the insurance will cover. its only if you're in desperate need. there is no way to fix water damage... but i know PLENTY of tricks to soak water out of the phone
May 30, 2009 | LG Dare VX9700 Cell Phone
Nokia 6085 does not recognize sim card
your card is trashed. the wwtnees corruped all your files. it you put it in a computer and it never registers than its offically dead
May 17, 2009 | Nokia 6085 Cellular Phone
LG VU screen doesn't work after water damage
I was cleaning the pool when my LG Vu took a dive. I fished it out in about 2 minutes...should have jumped in and it would have been in only seconds.....anyway. Dried it off with my shirt and pushed the lock button to unlock and see the screen...it was on but said Emergency Download. I took the battery out and dried it off also took out the SIM card and memory card. Shook the water out; some drips here and there, fortunately it wasn't water-logged. I let it sit for about an hour and got on the internet to find a remedy. I took advice to put back the memory and SIM cards and plug in to charger....the screen directed me to put in the battery....so far so good. The screen said the battery was charging. I waited patiently for that to finish. When complete, unhooked the charger and hit the unlock button again....what do you know the screen came up! I was estatic! But....the touch screen would not work!! Back on the internet for advice. Decided to do the hair dryer trick. I set the dryer on cool setting and let it blow on the screen. I also opened up the chargers portal and let air blow in there. I took the cover off the back to the battery and let it blow on there....being very careful not to let the battery fall out and not let the phone get hot. I did this for about 30 minutes. There was some fogging of the screen so I focused more on drying the screen with the dryer. The fog cleared up and when I touched the touch screen the top of the screen started working first...bottom still not responding...a little more of the dryer and all worked!!! Screen fogged again in about 20 minutes...dryed it again with dryer and it has been dry ever since. I have gone to every application, etc. on my phone and everything works just like it did before it took a dip! Hope this helps some of you! Key is patience, and some drying with TLC! Best of Luck!
Apr 29, 2009 | LG Vu CU920 Cellular Phone
LG viewty Water in touch screen
if your phone gets wet, putting it in a bowl of dry rice over night is supposed to dry it out. hope this helps. :)
Feb 10, 2009 | LG KU990 Viewty
Rained on T-Mobile Wing
While holding down the soft keys insert the stylus into the side of the phone (small hole on left hand side) should bring up a prompt to say if you continue you will reset your device....if you can get to setting there is a clear storage option, both master reset device. Good luck..
Jan 11, 2008 | T-Mobile Wing™ Smartphone
LG Vu CU920 Cellular Phone Logo
70 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
