Question about Canon ImageClass D880 Copier
Jammed paper I get to step #5 and after I am lost. I don't understand step 6 to what I see. Can you expand on this please. Also, I think my current problem is same as what your solution suggests as paper jamm occuring is back end of copier where normally copied paper comes out and where power line and phone line connect to copier. I don't understand Canon copier. This machine is rendered useless when paper jamm occurs from back end. I see no easy access panel to remove jammed paper from this machine without tearing it apart. Is this normal for other copier or is it just canon anamoly?
  • James_schnel Aug 07, 2008
    how do you remove the fuser
  • 42 Answers
Pper jams are removed from right hand side of copier-remove cartridge and lift green tab, check for paper there.
Paper jams in the fuser section are a real problem with this model the fuser unit has to be removed.
Posted on Jun 19, 2008
  • mark savelesky Aug 26, 2008
    Remove fuser from left end of copier.
    1. slide platen to left
    2.remove 3 plastic covers one above exit one to left of exit and lower cover where paper rests.
    pull back black paper to expose circuit board
    3. remove 3 connectors
    4.with offset phillips #2 screwdriver remove 3 screws
    which holds fuser to frame.
    5. lift fuser up and out carefully-hope you have small hands like Japanese!
    dont sweat the plastic covers they come off and on kinda funny and my explanation is made while viewing the copier dead on fron the PAPER EXIT SIDE.
HOW TO REMOVE BLOCK PAPER
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Oct 26, 2010 | HP LaserJet 1320 Printer
"Paper Jam" message displays despite there being no paper jammed. I have cleaned all the rollers and inspected as much as I can easily get to. Is there an easy fix or should I shop for replacements?
Oct 21, 2010 | HP PSC 750 All-In-One InkJet Printer
WILL NOT PICK PAPER SAYS PAPER JAM
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
Aug 17, 2010 | Dell 924 All-in-One InkJet Printer
The paper is jammed. How do i get it out?
hi
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Jun 27, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Paper was jammed, it split. We went through back of HP Officejet7310 to remove paper. After we removed it three lights came on and kept coming on without stop constantly. Auto Answer, Exclamation, and...
FLOWO THE STEPS
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 25, 2010 | HP PSC 1610v All-in-One Printer
It wont print
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 22, 2010 | Brother HL-2040 Laser Printer
Says paper jammed but this is not true
just try this,
1. Step 1
Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
2. Step 2
Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
3. Step 3
Look for paper through the opened back panel. Remove any paper you find jammed.
4. Step 4
Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
5. Step 5
Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
6. Step 6
Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
7. Step 7
Close the front access panel. Make sure that it latches back into place.
8. Step 8
Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Keeps saying there is a jam in the paper feed, when you open the front door there is no jam, reclose it and it will print
1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
8. Step 8
Thanks.
Have a good day.
Mar 17, 2010 | HP LaserJet 2420 Printer
HP 3419A
Hi Mose,
I never faced this problem any time , but could find a solution for you which i think will be helpful.
The paper jam error state occurs if the printer detects a paper at the platen after attempting to eject paper to the out tray. Clear the paper path.
<Power and Resume>
1. Turn the printer OFF and back ON to allow the printer to clear the jam.
(If the paper remains jammed, turn it back OFF and follow the remaining steps.)
2. Open the top cover and remove the OUT tray.
3. Pull the jammed paper out of the printer by grasping the middle section of the paper.
4. Remove all torn pieces from the paper path.
5. Remove any wrinkled or torn paper from the IN tray.
6. Reload the paper stack.
7. Replace the OUT tray and close the top cover.
8. Turn the printer ON.
Hope this answers your problem, Please let me know by providing your valuable feed back
Thanks,
Robosoft.
Dec 24, 2007 | HP Photosmart 375 InkJet Printer
Canon ImageClass D880 Copier Logo
156 people viewed this question
old marine
old marine
Corne Viljoen
