Question about Ovens
GE MODEL#JTPI5WD1WW (10 yrs OLD), REPLACING OVEN CONTROL, HOWEVER THERE IS A DIFFERENCE IN WERE WIRES ATTACH ON THE BACK OF THE NEW OVEN CONTROL - HECK, THE NEW OVEN CONTROL DOESN'T HAVE A GROUNDING TERMINAL LIKE THE OLD ONE ? THANKS
    President:
  • 1,796 Answers
HI!!
THE REPLACEMENT PART FOR THIS UNIT DO NOT SHOW ANY MODIFICATION, THIS IS A PICTURE OF THE OVEN CONTROL, CHECK IF IT IS THE SAME YOU HAVE. Part Number GE AP3140312 - Ovn control
KEEP ME POSTED!!
Posted on Oct 23, 2010
SOURCE:
I moved the latch for my jtp15 ge oven and now it won't open. What do i do to move the latch back over?
The latches on this model oven have a very high failure rate. Once the latch fails it is permanent. To open the door you have to access the control panel to reach the door look. To do this first turn the power to the oven off at the service panel by turning the breaker off.
  • Step 1 Remove the three screws from the control panel. The control panel is on the outside of the oven, above the door handle. Pull the bottom of the control panel toward you, then lift it up. This action will release the control panel cover's tabs.
  • Step 2 The mechanism that operates the door latch during the self-cleaning cycle will be behind a smooth, square plate held in place with two screws. White, black and red wires, as well as a grounding wire, will be protruding from the face of the plate. These wires will be twisted together with other control panel wiring and covered with electrical wire caps.
  • Step 3 Remove the failed part by removing the caps and untwisting the wires. Using an appropriate wrench, extract any screws holding the plate in place. The cylindrical-shaped mechanism will be attached to and behind this plate.
  • Step 4 Visit a store or contact GE at (800) 626-2224 to acquire a replacement part. To reassemble, slide the new mechanism into where the old one was and reattach the plate with the screws. Reconnect the wires by twisting them together and replacing the electrical wire caps.
  • Step 5 Replace the control panel by slipping the top of the panel into its groove and angling the panel downward, dropping the tabs back into the slots. Replace the three screws.
  • Aug 14, 2010 | GE JTP15 Electric Single Oven
    Replacing heat elements in oven
    To replace oven heat element follow the steps below carefully
    Turn off the power to the oven at the breaker box.
  • Step 2 Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
  • Step 3 Pull the element toward you a little bit until you see the wires behind it.
  • Step 4 Unscrew the leads and take the bad element out.
  • Step 5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
  • Step 6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
  • Step 7 Fasten the brackets, making sure they're tight.
  • Step 8 Restore power to the appliance.
  • basically to install the elements , place it in the same position as the old one. Connect it the same way the old one was connected, using the same screws to hold it in place. Just about all the other components of an electric range or oven
  • Jan 03, 2010 | Jenn-Air Ovens
    Is it easy to replace the keypanel of the GE
    Hello, The simple answer is yes it's not too hard...Normally you have a couple of screw located underneath the control panel. In most mordern ovens today they just consist of 2 components, the EOC (Electronic oven control) and the touch pad which basically cosists of everything you see(the whole panel). If you are replacing the touchpad..remove screws holding old panel in...pull wire harness from control board (dont worry where they go because the will only fit in one place) remove tape from EOC and relocate the control board to the new touchpad panel...reattach wire harness and tape in the new touchpad panel and hook back on oven ..screws in and your good to go. if replacing the control board (EOC) drop touch pad panel from oven and pull wires install new control then reassemble..easy!. One thing i would check though before purchasing the part, check to see it is the touchpad and not the control board...Here is how to do it...shut breaker off...pull out control panel...remove ribbon for key pad from EOC the re install panel..go switch breaker back on. leave for 24 hours..if within the 24 hours the error messages come back it's the EOC that is bad, if the error messages do not come back then you can be sure it's the touchpad. I would check this before buying the part since they are expencive and offten non returnable. Good Luck!! If you have any other questions or concerns please feel free to comment again. Thanks for using Fixya!! Mike
    Jul 24, 2009 | GE Profile JKP56 Electric Double Oven
    I need the squematic wiring GE 24" Built-In Gas Oven
    I have the same problem -- did you ever get this question answered?
    Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
    How to self clean
    Depending on the condition of the oven, it could take up to 4 hours.
    A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
    Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
    Here is a link for your stove:
    GE JTP18 Manual
    Directions are on page 23.
    Dec 13, 2008 | GE Profile JTP18 Electric Single Oven
    Old GE wal mounted oven Model J55BE-1
    I have the same problem. Did you ever find the solution
    Oct 05, 2008 | GE Ovens
    Replacing control valve...
    Be careful many ranges break the neutral... the ignitor always has power...I got almost electrocuted finding that out...
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    Oven Problems Replacing the Igniter
    heatman101
    Jul 02, 2008 | GE JGRP17 Gas Single Oven
    F2 Oven overheats
    jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
    Mar 04, 2007 | GE JTP15 Electric Single Oven
    Ovens Logo
    61 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Are you an Oven Expert? Answer questions, earn points and help others
