Question about Bose Wave music system large Remote Control
I have cd's in the other 3 slots. How do I get them to play
  • 712 Answers
Doesn't the remote control function well?
Posted on Oct 24, 2010
SOURCE:
Panasonic sa-ch64 cd is choosing the wrong cd
I looked at the users manual. I'm assuming single play slot zero is empty, if not unload it. Do you have your manual, if not, google your model number and select the search result 'manualslib.com', it can be found there. Recheck how your discs are programmed to play, sequential, block, etc. What you're seeing could be normal for how the unit is programmed. The disc was seen as being played, even when powered down, so the unit automatically selects the next disc. Some players attempt to read every slot , empty or not. Again, this may be programming. If a disc was loaded into the laser play position, was another disc placed in that tray position? Your unit has a wide range of programming/ listening functions, over time is could accidentally be programmed to other than what you are used to. Last resort is profession service. Good luck.
Dec 12, 2017 | Audio Players & Recorders
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
The unit rarely plays CD's anymore. It spins the
most likely a bad laser lens or out of adjustment.
Sep 21, 2009 | Teac PD-D2380 5-Disc CD Changer
I was putting CDs in my Philips 3-CD Player and
The best solution is to open the case and manually remove/realign the jammed cd.
Mar 13, 2009 | Philips Audio Players & Recorders
MODEL NO. CDP-CX455 MALFUNCTION
Sounds like a mechanical problem, I suspect taking it apart, cleaning, lubricating and reassembling will fix it. I have a workshop in SW London if you don't want to fix it. [email protected]
Aug 20, 2008 | Sony MegaStorage CDP-CX333ES 300-Disc CD...
Doesn't recornize Cd's and won't play cds
I have a AWM-2700U (3 disc changer) that was doing the same thing. I removed the cover and found that the laser lens for the CD player had come out of it "slot". I cleaned it with alcohol and a cotton swab and replaced it in the slot and it has worked for the past 3 months since. Hope it works for you.
Aug 20, 2007 | Sanyo AWM-2800 CD Shelf System
CD player stops to read disk two and nothing happens and won't play cd's
there could be a wine gum jamming it up honest i had the same trouble hope my knowledge helps u
Jun 30, 2007 | Emerson MS3100 3-Disc CD Changer
Playing CDs
An old post but did you get an answer and do you need a copy of the manual?
donald
Jun 29, 2007 | Bose Wave music system Multi-CD Changer...
Won't stop playing.
In the Carousel on the far left there is a slot marked single. Place your favourite CD in that slot and when it's bed time press the single button to the left of the Direct & Program buttons on the front of the unit. Then press play, only the CD in the single slot will be played. Enjoy. Always, Alvin T.
Nov 10, 2006 | Technics SL-MC50 CD Player
Bose Wave music system large Remote Control Logo
32 people viewed this question
Top Bose Televison & Video Experts
George Scott
George Scott
Jerry Greenberg
Jerry Greenberg
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
