Question about Frigidaire FRT15G4B Top Freezer Refrigerator
Samsung RS253BASB leak at bottom veggie drawer
We have a Samsung RS253BASB- a side by side. A small pool of water builds up on the bottom of the refrigerator side under the vegetable drawer and then leaks on to the floor. Maybe 1-2xs a week. My unit is 2 years old
There is a "vent" in the back of the drawer and the water filter is also on that side of the unit. Maybe the water is coming from either of those places? I have not ever changed the water filter, could this be the cause?
  • 2 more comments
  • wgehrhardt Jun 24, 2008
    leveled the box, check drain and tank on compressor top , has not helped
    leak seems to be at the bottom seam of the unit , no water found in the box
    it looks like it comes out the seam gasket also have light water on outer tin in back of veggie area no drain in this area.
  • Anonymous Aug 25, 2008
    Mine keeps forming a puddle of water under the vegetable bin. Checked the water lines and replaced water filter. Also the water dispenser works intermittently? Looks like a nice fridge but seems kind of problematic....
  • robinsontrib Feb 06, 2009
    Water pools under veggie drawer then leaks onto floor
  • Anonymous May 12, 2009
    this thing is a pos...I have hated this fridge ever since I bought it. Nothing but problems..
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email patmcclain@charter.net and I will send you this infomation.
Posted on May 13, 2009
The coils are thawing out which allows that ice build up to drain under the veggie drawer. The water dispenser works intermittently because the line freezes and thaws near the coils. What I can't figure out is how to keep those coils from freezing...ice is several inches thick at times. Not much of a solution, but it's all I can contribute.
Posted on Oct 10, 2009
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
Water leaking from my refrigerator
seems to be a condensation proble, is it possible to lower down fridge temperature a bit? This may solve the problem.
Mar 19, 2008 | Refrigerators
Samsung model#rs253basb side by side/ water pooling under vegi drawer & leaking out onto floor. water dispenser works when it wants too-not very often these days.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 15, 2011 | Frigidaire FRT15G4B Top Freezer...
Water accumulating in bottom of refrig under veggie drawers. Something plugged up? Thank you for any advice. - John.
Hello John,
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
I hope has helped answer your question,
Gene
Aug 04, 2011 | Sears Refrigerators
Water filter on my side by side Samsung refrigerator is leaking. Leaving a small pool of water under the veggie drawer and then onto the floor outside the refrigerator
Well first thing shut the water off,drain water out by removing filter ,check the o-ring on filter and if you recently changed the filter you possibly pinched it when reinstalling and now you need a new. If not it could have a flat spot on it and wore out either way you need a new on.Appliance store (get model # or take with to match up) or even at times a hardware store that sells o-rings.
Mar 27, 2011 | Samsung RS2630SH Side by Side Refrigerator
We have a slow water leak in our fridge. The water pools under the bottom 2 produce drawers.
On most newer fridges, there is a very shallow 'V' shaped collection channel at the back of the fridge just above the bottom drawers, this is for condensate collection. In the middle of this channel there should be a hole, this quite often gets clogged, and over flows, hence the water at the bottom of the produce drawers, clear the hole and it should cure your leak, worth checking every couple of months.
Mar 22, 2011 | Samsung RM255LASH Side by Side...
Water is pooling on the bottom shelf and in the
Hi I can help you with this annoying problem.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 14, 2009 | Refrigerators
Small amt. of water dripping from behind veggie bin
Hi, It sounds like the tank for the fresh water dispenser. Is it coming from the tank on the back wall of the fresh food section?
I can not find the part # but, if this is the source of the leak, I can give other ideas.
Please let me know if I can assist you further.
Vic
May 24, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs21wcns has a leak
I found my leak, after checking all lines, connectors, couplers, behind the second to bottom drawer from what appears to be a cooling resevoir. It appears the seams are slightly leaking on both sides. I found water pooling under the bottom drawer and then leaking out the front and followed it back. My Samsung is model RS2556SH
Jul 04, 2008 | Samsung RB2155SH Bottom Freezer...
Water pooling under my express thaw bin in bottom of refrigerator
no connection between lower drawer and water dispenser, however there is a water tank behind the crisper's storing water for the dispenser, its possible that there is a hole in the tank or a connection is leaking there and dripping water. remove all 3 crisper's and give a look at it. try getting water from dispenser while your checking (Might only leak when water dispenses
Mar 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRT15G4B Top Freezer Refrigerator Logo
1,364 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
