Question about Indesit Washing Machines
Hello.i have an indesit w182.i start a program 4,for example,after the machine doing the first injection of water,before the second the program button start to rotate and at the same time she start to trow the water out.can you help me?
SOURCE:
  • 139 Answers
SOURCE: washing machine
The knob keeps turning when you have a problem with the machine the most common problem with indesit is the pump. check to see if there is any thing in the filter compartmet located at the bottom on the front of the machine if so clean and replace.. THEN you will have to reset the knob. you do tis by turning the dial to one of the off position (the big black dot ). Then leave the door open and keep switching the machine on and off quickly from the button on the front of the machine untill you c the lights flicker rappidly.. once this happens the machine is reset and ready to wash ... p.s The pump can be one source for a problem... others include brushes on motor.....but most likely it will be the pump tell tell signs are water in the drum
Posted on Nov 21, 2007
barkencoa
  • 3463 Answers
SOURCE: dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Posted on Dec 09, 2008
  • 82 Answers
SOURCE: when i turn on my indesit WIL 153 washing machine
It's either a short in the heating element or the motor is faulty.
Disconnect one then the other and re try.
Hope this helps.
john
Posted on Aug 28, 2009
  • 197 Answers
SOURCE: my indesit washing machine not rotating,
Check carbon brushes on motor, only if you know what you are doing!
Posted on Oct 30, 2009
SOURCE: Program switch of Indesit-WD105T starts rotating
I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
Posted on Oct 08, 2011
Indesit washing machine IWC6165 will not start a wash cycle.
my Indesit washing machine start washing normally taking water and spinning and draining but for each cycle i have to do manual its automatic cycle is not working by it self the way it meant and suppose to be . for example if i start on number 3 to wash it just stay on number 3 not moving to next cycle . plz can anyone knows why this happen .?
Dec 23, 2012 | Indesit Washing Machines
Hi, I was going to wash a machine this morning - I have an indesit WIDL 106 Washer-dryer. But as I press the start button all the lamps on the control panel start to blink rapidly and they blink...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. The processor of the program controller has hung up and so the display is indicating with the blinking. This can be a failure of the program controller unit which must be estimatted. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
please check the link for support, post your request to
http://www.indesit.co.uk/indesit/entryPoint.do
Jul 02, 2011 | Indesit Washing Machines
My indesit front loading wg1432 model washing machine wont do final spin at the end of each programe, the rest of the programe is fine, just when it comes to final spin the dial stops at this point
hello it might not be draining enough water out it has to pump water out before it spins check the pump also the filter if it has 1 hope it helps
regards
shaun
Mar 14, 2011 | Indesit W 123 Front Load Washer
I have an Indesit W1A111 and it spins, drains, rinses etc. It does everything it should do but if you put it on a programmed cycle it wont go pass the wash. For example if I put it on number 4 and press...
The normal procedure to reset the program of Indesit and like machines is to hold the start button for a a period of time in an attempt to reset the logic/programing. If unsuccessful, unplug the machine for a period of 5 to 10 minutes reset the selector to the desired program and hold the start button in hopes of clearing the memory of any previous commands. If this does not cure the problem the most probable causes are:
one or more of the 6 to 12 sensors (varies according to model and year of manufacture), around the drum, water drain pump, humidity sensor,ect.,has developed high resistance/corrosion contacts or due to vibration of wash and spin cycle, has shaken wire/contacts loose. If this is the case, remove the top cover plate for access. Clean and reseat the contact/connectors also check for wires loose in the connector, as they are simple compress crimps. The most probable suspect is visible on a duct, which is at top center over the drum. I would suggest that all receive service while you have the top off to avoid do it again in the near future. If this fails to clear the problem it is most likely a failed module requiring identification of the failed module and replacement.
sincerely Doc Michael
Mar 07, 2011 | Indesit W 123 Front Load Washer
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Oct 19, 2009 | Indesit Washing Machines
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
INDESIT DW S 60
check and make sure the door switch is activating
Jan 03, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Washing machine
this indicates a fault unfortunenately it doesnt say which one the most likely problem will be brushes in your motor
Jan 01, 2007 | Indesit WA 115 Front Load Washer
Open Questions:
Washing Machines Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
