I have a HP 7410 printer, scanner & fax. Can you help me get the scan part working--fax and printer is working
  • 7,733 Answers
Try here..
Posted on Oct 24, 2010
SOURCE:
Hp officejet 7410 will not fax or scan
Needs little bit technical skill level to do this activity:Open adf unit, remove flat bed glass, take out CCD unit, open bonnet of CCD, clean reflcted gasses with smooth cotton cloth or ear buds(no solvents requited) fix it back, clean glass both side, fix back all, try it..best of luck..Pl see the snaps for help:
Feb 04, 2012 | HP OfficeJet Office Equipment & Supplies
My HP 7410 All In One has works great except the scanner has never worked. When I push the scan button I get " you need to install or run HP software for this feature". I reinstalled the software...
If that is the case then reinstall the driver again but be sure to unplug first the printer usb cable and just follow the instruction when to plug in the usb cable. Good luck
Jan 12, 2011 | HP OfficeJet 7410 All-In-One InkJet...
The scanner won't scan to the computer, but when I test it in scanners & cameras it says it is working.
This is my solution :
1st step : Turn on your *HP Deskjet F4185*.
2nd step : Click the Start menu.
3rd step : Click Devices and printers. A new window will appear.
4th step : Then, click the "Fax button ".The window Fax and Scan window will appear.
5th step : On the lower left corner , click "Scan" below the "Fax" button.Scanned documents (if there's any) will appear.
6th step : Click "New scan" button below the "File" button. And your printer will start! Glad to help..
Mar 29, 2010 | HP DeskJet F380 All-In-One Printer
Hp officejet 7410 all-in-one scanner don't work half the time.
Perform a hard reset on printer and also uninstall completely all software and then reinstall. Try scanner again.
If you have "upgraded" to another OS there is a possibility that the driver being used is not good for the new environment. If applicable, check that out.
If printer is out of warranty HP will do nada but refer you to a forum or suggest you get a new printer - an HP naturally!!!!!!!
Aug 27, 2017 | HP OfficeJet 7410 All-In-One InkJet...
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 Scanner Failure
Sorry, you have a bad scanner assembly which will cost more than a new printer.
Jan 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Scanner FailureTurn power off then on again Message Window pops up continuously
Below is the document that i want you to follow.
CLICK HERE ===>> DOCUMENT
Pleae let me know the result after performing the steps.
thank you so much.
adonscott
Jun 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7410 prints OK, but copy and fax comes out black all but 1 inch
The problem is on the scanner...
You have to change "scanner assembly". But... here in Greece this unit has not spare parts.... The repair procedure is "unit exchange". You have to contact HP Service in order to inform you if they can change only the scanner assembly and not whole unit... You can call telephone support.
Apr 07, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Scanning from HP OfficeJet 7410 All-In-One to a Mac
Had same problem. Make sure you've closed any other apps. Itunes caused mine to fall over.
Jan 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Scanner not recognizing software
try opening the scanner from the START-ALL PROGRAMS-HP-ALL IN ONE
Jan 11, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Computers & Internet Logo
26 people viewed this question
Ekse
Alun Cox
