Question about HP OfficeJet 6210 All-In-One InkJet Printer
My HP Officejet 6210 All-in-One printer goes offline whenever I don't use it for about 15-20 minutes, and when I put it back online, nothing happens. Looking at the printer from the control panel, I see "Error-printing" next to my print job. I cannot delete the print job while that error message is displayed, even though it says it's being deleted. If I try to print something else, I get the same "Error-printing" message. Often if I turn it off and back on, it will print, but I'd really like to get rid of this problem.
    Novelist:
  • 256 Answers
The users who are experiencing offline errors while using the HP printers are suggested to check the connections, settings and printer hardware before proceeding any further.
The connection to and from the printer shall be verified thoroughly by the users and any anomalies if found shall be fixed then and there.
As these errors can also be caused by printer hardware issues, the users are suggested to check with different key components of the printer like the cartridges, feed tray and more and fix any issues if found.
Restarting the printer and the computer after following the above mentioned procedure will help in solving and preventing the offline errors with your HP printer.
Get more help to fix HP printer offline error . Hope this helps you.
Posted on Jul 05, 2011
  • HP Master
  • 1,679 Answers
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer
While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Posted on Oct 23, 2010
SOURCE:
I have an HP Officejet 6210 All-in-One Printer Whenever I turn the printer on now, it will draw in a piece of paper, and spit about half the paper out to the "out" tray and then promptly...
To me is seems issue with the hardware try to RESET the printer and for doign that follow this
1. Unplug the power cord from the back of the printer while the printer is ON
2. press and hold # and 6 button at the same time
3. while holding them plug in the power cord
4. When you see the lights on and a progress bar on your LCD screen release the buttons
it will take a minute or 2 and will reset the printer and it may fix the problem
Apr 17, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have the same problem as zjboza had on Jan. 4, 2010. My HP office Jet 6240 is offline. How do I get it back online. THis occur quit frequent.
If you have Windows operating system
Windows XP
Click on
Start >> Control panel >> Printers and faxes
Under Printers and faxes you will find an icon of your printer Officejet 6200 series
Highlight it - Right Click and you will get an option which says- Set printer online
If windows 7
You need to go to printers and other hardware and then printers and then the process is same
Apr 01, 2011 | HP OfficeJet 6210 All-In-One InkJet...
It says that my officejet 6210 is offline when i go to print, everything is plugged in though and ive restarted it a couple of times. Was working fine before and now its not.
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
And:
Go to Start-->printers and faxes-->right click on the printer-->properties-->make sure it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 10, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Tells me it is offline.
Press the ONLINE/OFFLINE button on the printer.
In Microsoft Windows, click Start
Click Control Panel
Click Printers
Right-mouse click on the HP printer, and click to go "online".
Dec 30, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My HP officejet 4300 series stopped printing and shows that it is offline. How do I get it back online?
To get back online of your printer, go to Control Panel and Select Printer & Faxes then OPEN.
A list of Printer is on the browser, point the printer with your mouse then right click on your Printer HP OfficeJet to select Printer Offline and click it to go back Printer Online. Good luck!
Aug 04, 2009 | HP Officejet 4315 All-in-One Printer
I need to see a user manual for hp officejet v 45 all-in-one
GO ONLINE AND ASK FOR IT
HP OFFICEJET 6210 USER MANUAL
OR
HP OFFICEJET 6210 SERVICE MANUAL DRIVERS
OR
HP OFFICEJET FOREM USER GROUP
OR
WWW.HP.COM/OFFICEJET
ROD
Feb 09, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet L7780
Do you have the latest drivers for this printer using vista?
Go here http://h10025.www1.hp.com/ewfrf/wc/product?product=2512010&lc=en&cc=us&dlc=en&submit.y=7&submit.x=5&lang=en&cc=us
for the latest drivers, software and support for your product
I hope this helps
Oct 20, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
6210 officejet all in one printer
check your cartridge try to change thoase cartidge.
Sep 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 6210
In order to set back the printer to online, here are the steps that i want you to do.
1. Right click the printer ICON
2. CHoose option, USE PRINTER ONLINE.
3. Try printing again, that should work.
Goodluck.
adonscott
Aug 08, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
342 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
