Question about Panasonic KX-TG6700 Cordless Phone
KX-TG6700 Freeze My base unit is freeze and all the lights and indicators are on I unplugged and plug again but the problem remains
  • 2 more comments
  • guazco Jun 12, 2008
    My KX-TG6700 is frozen, the difference is that only the sp-phone ligth is on, nothing works, I need to program an extra handset but it is imposible. Could you help me?. Thanks
  • atothek Oct 14, 2008
    Same deal hope there is assistance soon!
  • hesantos83 Jan 01, 2009
    it didn't work for me still the same here..
  • Pedro Molano Jan 13, 2009
    I try what you said but we don't know what ribbon cable we need to pull awy from the circuit board. Could you please explain to us? Thanks, Molano's Family
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Remove the base by taking out the five screws. Look for the ribbon cable on the left hand side. On each side of the cable is a little brown nub, pull away from the circuit board to release the tension. Pull the ribbon cable out, this will reset the circuit board. Put the ribbon cable back in and push the nubs towards the circuit board. This will add tension to the connection. Put the base back together using the 5 screws. Plug in your phone and you should be set.
Austin Ron
Posted on Oct 27, 2008
I had the same problem - all the lights were on but the unit wasn't working. I called the local Panny service center and they told me it was either a bad ribbon cable or a bad circuit board. It's $35 to have them look at it and another $20 to replace the ribbon. If the circuit board is bad then you throw the phone away.
But I did get mine to work using the suggestion by Austin Ron with one modification. I removed the back and located the ribbon cable on the lower left side. (It's the only ribbon cable that I could see.) I pushed gently on the brown nubs to release the cable and then reattached it. But after I put it all back together it still didn't work. On the next try, I plugged in the power cord while I had the back cover off, played with the ribbon cable again and this time it reset itself. I then attached the phone line and got a dial tone. But now the phone only works with the cover off. Also, the buttons on the main base don't work and all operations have to be done through the handset. But, at least I can use it to make calls until I decide which phone to buy next.
Posted on May 27, 2009
Exact same situation as "crarycurt" (black marks on ribbon leads), and did the same thing. it reset, but ANSWER ON button was still frozen lit, and the phone nor the base worked would get a dial tone. i tried one more thing. I disconnected the ribbon on the other board (the one underneath, when you open up the back of the phone) and turned the ribbon around an inserted the each end into the opposite connector. now like "crarycurt" the base station seems dead the phone works! i'll take it. thanks all for the tips!
Posted on Jul 04, 2010
I had the same problem with my panasonic phone system. The brown ribben cable seems to be the issue. When I pulled mine I noticed there was black on the silver connectors. Perhaps this is the route of the problem or in the alternative this is where the heat melted some of the solder on the ribben end. Anyway pull the cable and both lines started to work but as soon as I put the unit back together the same problem appeared (all lights on and no dial tone) The solution seems to be that you need to plug the power chord in and then while the power chord is in you reattach the ribben cable. Not easy but doable. This seemed to work at getting the system back up and running however the base station buttons are all dead - BUT THE PHONES WORK!
Posted on Jun 29, 2010
I did what Austin Ron said, but before I put the base back together, I've plugged in the power cord and one phone line, while I had the back cover off. Immediately the phone "spoke" saying the line one was set. Then, I put the base back together, recharged the phone and the extensions and I was all set. Thanks Austin Ron and Jim Win.
Posted on Sep 08, 2009
Panasonic KX-TG6700 Phone
test the adaptar if working try it in another phone
2) sure the the line cord is plugged firmly in the phone base
3) unplugged the phone base . Wait from 30 seconds, and plug it again. Allow up to one minute for the cordless handset and phone base to synchronize.
4) charge the batteries by 16 hours aprox.
5) if the batteries is completely dead can take 30 minutes before low battery appears on the screen.if doestnot work replace battery by new ones.
try agan.
Oct 03, 2012 | Panasonic KX-TG6700 Phone
Panasonic KX-TG6700
Did you try disonnecting the unit from the power for a few hours?
Apr 13, 2008 | Panasonic KX-TG6500 Cordless Phone
How can i set up speed dial?
Registration Register the handset to a KX-TG6700/KXTG6702 base unit. 1 Base unit: Press and hold {INTERCOM} until the IN USE indicator flashes. L After the IN USE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 2 Handset: Press {OK}, then wait until a beep sounds.
http://adcombhs.com/shopsite_sc/store/html/Panasonic_KXTGA670.pdf
Mar 07, 2011 | Panasonic KX-TGA101S Cordless Handset
Cordless phone does not work
ok i found a solution...
for good measure, unplug everything from the main base, wait a few minutes, then plug everything back in. this never solves the problem, but it's standard troubleshooting procedure.
next, follow the menu instructions on the non-working handset to re-register.
if the re-registration doesn't work, your handset is probably shot. you can buy a reconditioned one on ebay for under $30. take the battery out to find the model #.
Jan 10, 2009 | Panasonic KX-TG6700 Phone
Panasonic KX-TG6700
I have the same problem and I simply open the base (5 screws at the back), disconnect the cable that came from the keypad located (if you see the station from the back) at the left, turn on the base without connecting this cable. After that, I unpluged the station, reconnect the keypad cable and connect it again. Solved.
Jan 21, 2008 | Panasonic KX-TG6500 Cordless Phone
KX-TG6700
These units have a problem with the base unit going bad, often caused by a power surge. The symptoms are, in addition to the above, none of the buttons on the base unit work. I found a partial work around that gets all the lights off and the system working, but the buttons on the base unit still don't work. Not really a problem as the answering system still works and you can retrieve your messages from any remote by pressing Menu and then the LCD button "Select" You have to be a tear-it-apart-type to try this but here is what to do
1. With a small Phillips screwdriver, remove the base from the cover by taking out the 5 Phillips screws.
2. Next unplug all lines to get the cover and base separated.
3. Locate the flat ribbon cable connecting to a connector on the edge and disconnect it by pulling out (away from the connector) the two locking tabs.
4. Plug in the power and reinsert and relock the ribbon cable
5. Check the lights. If most of the lights are off unit is ok and you can disconnect the power, reassemble, and reconnect all wires.
6. If reconnecting the power causes all lights to go on again, you have the same problem I had, for which the solution is tougher and only temporary
7. Repeat all of the above steps but do not disconnect the power when separating the cover from the base. This will make it impossible to completely remove the cover from the base, but you can tilt the cover up enough to be able to access the ribbon cable to disconnect and reconnect it.
8. Lights will now stay on as long as you never disconnect the power or have a power failure, in which case you have to repeat the above. I wound up hooking up mine to the same outlet strip I had connected to my uninterruptible power supply (UPS).
Jan 02, 2008 | Panasonic KX-TG6500 Cordless Phone
Can't reset Panasonic KX-TG6700 phone
I have the same problem,,,
Dec 11, 2007 | Lands Phones
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Freeze up
my mp3 is freeze and not turn on.
Oct 12, 2007 | Panasonic KX-TG6700 Cordless Phone
Panasonic KX-TG6700 Cordless Phone Logo
439 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
