Question about Nikon COOLPIX S230 Digital Camera
Every time i turn my camera on it says lens error, what can I do to fix this?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 02, 2012
SOURCE:
  • 102366 Answers
SOURCE: Lens error won't go away
Sadly, the camera needs service.
Posted on Dec 30, 2009
  • 102366 Answers
SOURCE: Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
Jimsta01
  • 405 Answers
SOURCE: my digital camera has a lens error
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Posted on Jul 24, 2010
lock123
  • 6831 Answers
SOURCE: when i turn the camera
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Jan 13, 2011
lock123
  • 6831 Answers
SOURCE: lens error
Hello
Regards
Andrea
Posted on Jan 25, 2011
My digital camera has a lens error
Jul 24, 2010 | Nikon COOLPIX S570 Digital Camera
I have a Nikon s220 coolpix and everytime I turn on the camera the lens opens, makes a strange noise and closes - it does this 3 times and then I get a lens error message on the screen. Do you know what is...
Jul 02, 2010 | Cameras
Lens error; restart camera
Jun 15, 2010 | Canon PowerShot SD600 Digital Camera
Lens error :0x01110000 That's what it says when
Jun 12, 2010 | Pentax Optio 60 Digital Camera
When i turn my camera on i get a lens error 113,0,0,0 what is that and how do i fix it?
The lens/zoom has tendency to stick. Try newest batteries and try several times to turn on and off. If all else fails, Kodak will fix it for $50
Jul 02, 2009 | Kodak Easyshare M753 Digital Camera
Lens error response
well not a lot to go on here is there?
what sort of error.. turn power off and on again ? the lense oes in and out 3 times and then says turn off power and turn on again?
if this is so, use some canned air and blow around the lens joints when turned on, turn it off and on to see if that fixed it. If not turn off power bang face down on palm several time ( no its not a joke) then turn it on again,keep doing this untill it clears it will save you $175
Jun 20, 2009 | Nikon Coolpix 2200 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
"Lens Error, Restart Camera" Lens stuck open, completely disfunctional! /sadface :(
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Apr 17, 2009 | Canon PowerShot A630 Digital Camera
Lens Error
Dec 17, 2008 | Nikon COOLPIX L4 Digital Camera
Nikon COOLPIX S230 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
