My tv keeps turning channels over randomly, the volume goes up and down, it hasnt started turning itself of tho so this is ok, but it just turns over all teh time, its really annoiyng. My tv is a beko freeveiw 26" and i would like your help on this is you could please.
SOURCE:
trintek
  • 111 Answers
SOURCE: TV CHANGES CHANNELS (BY ITSELF)
is this tv the same model/brand? far be it from me to claim poltergeists are at work, but who knows... the very first thing i would do in diagnosing this issue is to grab some electrical tape and aluminum foil, tape a patch over the ir receiver for the remote, this should be a shiny piece of black plastic somewhere on the front of the tv, some are marked, some are not.. if you have it, aluminum duct tape works great for this purpose.
to me, it seems like someone is messing with you using a remote, tv-b-gone, or similar product like a keychain universal remote.. if the tape over the ir sensor fixes the issue, i would look at roommates, kids, neighbors, or possible interference from other ir or light sources..
possible culprits would be:
universal remotes
dirty remotes that keep sending a signal with nobody using it
laptops or cellphones with an irda port
palm devices such as palm, clie, etc that have irda
intermittent strobes (emergency vehicles, bad ballast in a light fixture, etc)
i can't guarantee this is your problem, but it seems like it since this is your second tv with the same or similar problem... as a sidenote, the sony clie came with a universal remote program, i caused much chaos in my local video stores by shutting down their video wall while browsing.
Posted on Nov 16, 2007
  • 286 Answers
SOURCE: ViewSonic N2750w 27 in Volume turns down by itself
Could be a problem with the down volume button on the tv. the board it's on ir its harness. Check them all. Make sure the volume buttons plastic actuator moves freely and is not stuck.
If these parts are all good, you have a problem on the main board. You may have to trace the control lines as far as you can and check any capacitors along the way. If you have an oscilliscope you can test the lines to see if the up volume is working correctly. If there is noise on it, you might find a bad capacitor if you can trace it back far enough. Schematic helps here.
Of course, make sure nothing is shining on the sensor window on the TV. You might want to scope that line as well (IR sensor line).
If none of that helps, get hold of Viewsonic and find your closest service provider. You can order a main board from them.
Of course, you could try just using the audio out jacks to an amplifier or a surround sound amplifer. Then you would use the remotecontrol for the surround sound system to control your volume.
Bet you were going to buy one anyway right?
Posted on Feb 14, 2008
SOURCE: Volume n my tv keeps going down
same
Posted on Apr 15, 2008
  • 362 Answers
SOURCE: blank screen beko lcd 26" lcd tv - sound ok (model no. L5A)
While you have sound, take a flashlight and shine it on the screen, look very close and see if you can see a dark video image.
Let me know what you see.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 08, 2009
  • 458 Answers
SOURCE: i cant receive freeveiw channels
I don't know what make of TV you have but some manufacturers have two tuners at the rear of the TV. One for terrestrial signal & one for digital signal. If this is the case put the aerial into the digital input & try retuning. If this does not work then if you could provide the details of you TV eg. make & model, then I will try to help you further.
Posted on Jun 30, 2009
Hi I have a THORN hd smart tv 55' turns on but then just black screen sound is fine can change the channel but can't see a thing tried unplugging it holding power button down for 60 sec
I have a 55inch thorn TV not a smart TV Tho n it keeps randomly turning off day and night n once it flicked from hdmi channel to normal TV channel, no set some or anything I'm worried a fault or boogidy, it's bout 5 or 6 years old n only been doing it the last week ??
Mar 31, 2017 | Televison & Video
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
Jul 06, 2008 | Televison & Video
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
Televison & Video Logo
Top Televison & Video Experts
Ekse
