Question about IBM ThinkCentre A30 PC Desktop
I have a old ibm desktop model 819933u. I need instructions on h ow to install ram on the pc. A picture would help/
  • IBM Master
  • 7,733 Answers
Is very easy.
1-One of the sid epanel of the tower had 3-4 screws,unscrew them.
2-Most panel can take out by slide back.
3-After this locate the RAM slots,and slot had on each end 2 secure handles,push them down,until the RAM sticks come up/out.
4-Do same procedure in each.
5-The new one is the same, but reverse procdure.
warning:do not touch the RAMS metal connectors with your fingers.
Posted on Oct 24, 2010
SOURCE:
Ibm audio driver pentium d
The same model ThinkCentre can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkCentre, you need to download all the drivers and install each driver until you find the right driver. When you download the drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive. Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows device drivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Nov 14, 2012 | Lenovo IBM / ThinkCentre / ThinkCenter M55...
Ibm m50 vga driver
Get onlineand got to www.google.com In the google search box type: "IBMSupport" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Apr 05, 2012 | R.A.M. Computers ThinkCentre M50 8189 -...
I have an IBM NetVista PC model #830781U and want to install additional memory...1GB chip... How do I do it??
Ok, first of all before installing the ram, you want to make sure the ram you are installing into your computer if the motherboard support the type of ram chip you are installing it in. For your model it is ddr184 pin After this, you can take out your case panel which is the left side by unscrewing the 2 screws in the backside of the panel. Carefully take the panel apart from the computer and set it aside. What you want to located is the RAM slot on your motherboard which typically is 2 slot next to the cpu which has the big fan. Most likely one of the slot or both of the slot is already accompanied by the old memory chip. There are two hinges one on each side, bottom and top. Push these pins down and it would loosen up the memory chip that is already installed on. Replace the new memory chip and make sure you align the golden tooth pins extacly to the memory socket and then push down on the chip until it clicks. Test your computer if it works, if not. You computer may not support the memory chip.
Jan 13, 2011 | IBM NetVista PC Desktop
I have Ubuntu 10.10 installed on my IBM R40 laptop computer. Although I installed two 512 MB PC2100 266 Mhz memory to both slots. However the computer only sees 512 MB. When I installed Ubuntu I perhaps...
Well, what a mine field!
I found this;
There are at least 9 different R40 Thinkpad models. Look for a label underneath & see if there's a "Type" number...something like 2681, 2682, etc. Once you find the number, go to the following site & select your model/type from the dropdown menu:
http://www.crucial.com/store/listmodel.asp?cat=RAM&mfr=IBM&productline=ThinkPad&submit=Go
And being a 256Mb standard, that may be all it can handle. The above link is rather old but worth a try.
Hope this helps.
Jan 02, 2011 | IBM Computers & Internet
Are there any lazer printers avialable for a PC 300PL IBM with only 84 MB RAM? At one time I had an HP.
For an old PC like that, youd need a Serial port. For a Laser printer, this is odd. However, there are adapters you can use! Ask your local BestBuy or Staples store for a laser printer and a serial adapter for it.
Hope this helps!
Sep 02, 2010 | IBM PC 300PL PC Desktop
I am install xp sp2 on intel pantium 4, ddr1 ram(256mb), intel mother board & lost sound & display drivers so help for download these driver
Go to IBM's official website. Click on free drivers download. Select your model and operating system. Download drivers and install in your PC.
Aug 03, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
Slow computer with 256 MB,
try to increase the irual Memory by 1.5 times
Mar 24, 2010 | IBM PC 300GL PC Desktop
Ibm 845 e motherboard problem
IBM Netvista PC is not ready for Windows XP, you should update its BIOS on its version so that you can install windows XP, maybe ACPI is not ready yet for this motherboard compliance to Windows XP, so download it at www.ibm.com
Jul 21, 2009 | IBM NetVista PC Desktop
Would there be any 32bit PCI expansion slots on an IBM windows98?
There are PCI slots, but the processor, ram, and video capabilities are far below what modern components expect. You probably could get the wireless card to work, make sure the manufacturer has drivers for Windows 98 before you buy the card.
In my opinion you should maximize your RAM. For a Dimension 2400, Dell's manual claims the min is 128 Mb and the max is 1Gb. Not sure how you got to only 32Mb of RAM but you'll see a big improvement in performance if you increase it.
Do you have an old IBM or a Dell (the area you posed the question in)?
Jan 08, 2009 | Dell Dimension 2400 PC Desktop
Ethernet driver does not work for IBM Thinkpad A20m
hi good day to you I have problem in my laptop thinkpad A20m PIII 700mhz 256 ram running in widows XP,, and everytime I install the driver of Lan the massage appear error in code 10, and the lan is not working,,can you help me in this problem?
Jan 12, 2008 | IBM ThinkPad A20M Notebook
IBM ThinkCentre A30 PC Desktop Logo
353 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
