Question about Kenmore Washing Machines
Kenmore 110.2691269 0 when washing leans to left spin the same and make alot of noise off balance has 3 short springs an 1 long
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.fixya.com/postanswer.aspx?thid=6534005&prdid=0&ctgid=0&ref=unsl
Look at the Machine Base section and you'll see how the springs connect.
Also make sure that the Pads are not broken and are in place.
Also see the Whirlpool / Kenmore Service manuals for these machines.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Posted on Oct 24, 2010
SOURCE:
The tub of my toploading washing machine leans to the front right, It is balanced and leans whether clothes or in it or not. I can spin clothes if I prop lid open and hold tub straight .
The suspension springs have gone out of alignment or the tub holding mechanism is shifted. look throught the bottom to see the fault in the suspension. correct on the mountings.
Even a leaning can come if the motor suspension is out of alignment.This must be centered in and the top door will close evenly.
Sep 01, 2010 | Kenmore Washing Machines
Tub free hits side of washer when trying to spin
1- Clothes load is not balance. 2- Tube is balanced by several springs from the bottom tube to the chassis. If one of these springs is broken or slipped out the tube will lean to onside causing this problem. Check these out.
Jan 09, 2010 | Washing Machines
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Sides vibrate during spin causing a lot of noise and machine moves. could it be out of balance?
1- Clothes are not balance inside the tube. Try to rebalance the clothes when it happens. It usually happens when towers leaning on on side when water level selector not set appropriately. 2- Try to level the washer by adjusting the leg screws at the bottom of the washer. 3- It make a lot of noise since the whole washer moving against the floor. When it spin only the tube then it won't be like that.
Jan 02, 2010 | Kenmore HE3T Washer
I have Kenmore 60 series large capactity washing
There are two or three springs that hold the drum upright and level. They are attached to the motor and the drum base or sides. You have a broken spring. From being overloaded or turning during a last spin cycle it was out of balance and broke a spring. The machine will have to be taken apart to expose the springs. They are about 4-6" long. If the mounts are Ok replace all springs.
Oct 17, 2009 | Washing Machines
My Kenmore front load washer just bgan to goes out of balance
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 08, 2009 | Kenmore 43142 Front Load Washer
Making a loud noise when on the spin cycle and not balanced
It could be a drum spring has broken or stretched too far, there is too much of a heavy load in the drum, or the bearing needs replacing.
Sep 11, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My washer was in spin cycle I hear a loud noise now it is way out of balance when in spin cycle as it bangs
Aug 04, 2009 | Kenmore Washing Machines
Wash machine makes a noise when it spins like it is out of balance
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Apr 06, 2009 | Kenmore Washing Machines
Washing Machines Logo
64 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
