Question about Whirlpool Washing Machines
I have a whirl pool duet and there is a load in the wash right now. The cycle stopped and the screen in flashing 02 then it blinks F back and forth to each other.
    President:
  • 1,554 Answers
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Posted on Oct 24, 2010
SOURCE:
The washer right in the middle of a wash cycle it will stop and blink F02
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirl pool washing machine tries to fill up but never fills up
This means it is stuck between the spin and rinse cycle and the time piece in the housing unit might need replaced if the knob itself isnt stripped also make sure it is on small or large load..
Dec 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Code 02 F
pump is obstructed and needs to be cleaned. Look in this thread for how to clear a duet sport pump trap.
Dec 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops at 2 minutes and a letter "f" blinks
I had the same problem. It would flash f then 02,
click this link and you can fix it in about 5 minutes.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer does not go past wet cycle
if your vent hose is clogged, your element most likely burnt open
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F flashing followed by a 2
F/02 Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Feb 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
The time remaining on the wash cycle is blinking door is locked
M duet was also haveing problems and when it would stop in a cycle it would flash a leter and a # F 02 I hit cancel and restarted it the time was all messed up I looked up the code for F 02 and found this page, I will post the link below. it was a drainage problem I cleaned out a trap in the pump really easy to do and it just might fix your problem. Regardless ever Duet owner needs to know this and matain this trap I pulled out a bowl full of stuck in it. Good luck!
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Dec 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
96 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
