Question about Maytag Neptune MDE5500AY Electric Dryer
Changing the wheels
I opened the front and took out the drum and my 7 o'clock wheel is not spinning. How do you take it off and install the replacement?
thanks
Lee
  • 525 Answers
The drum roller is held in place with a TRU-ARC snap ring, which looks like a C with 2 small holes in each end of the C. This is located on the front of the roller shaft and can be difficult to see. These ordinarily require the use of a TRU-ARC snap ring tool. However, I can guess that you don't have this tool, so, a putty knife, butter knife, or other thin blade, dull, tool would suffice Carefully wedge the blade in between the ring and the roller and gently twist the tool to force the ring out of the groove that it snaps into DON'T lose this ring! Slide the old roller off the shaft, clean and lubricate the shaft with Poly lube, slide the new roller on and reassemble. Of course the snap ring will have to be partially inserted into the groove, and forced the rest of the way with something like a ratchet wrench socket that fits against the ring,(not over it), and push to engage it back intio the groove.
Hope this helps! Repost me if you need more assistance,
Dave E. (Illeagle)
Posted on Jun 08, 2008
  • David Emmel
    David Emmel Jun 11, 2008
    Hey Lee,
    Just checking back to see if you got the roller changed or needed more help.
    You can post me back or if I was helpful, would you kindly give my resolution a rating?
    Thank you for contacting us at Fixya.com
    Dave E. (Illeagle)
My dryer comes on and spins, heat comes on but clothes do not dry. I took the front panel off, it fires up but it doesnt get hot in the the drum.
Try checking the blower wheel just behind the front panel and see if it's loose or if you spin it without the tub moving, the blower wheel is probably stripped or you have no air flow. Take the vent off the back off unit see if you have air flow there. Remove all excess lint you see anywhere
Oct 28, 2013 | General Electric DHDSR46EGWW Dryer
1999 plymouth breeze. step on brakes and the front brakes have a bad pulsing to them. previous owner hab brakes done rotars turned and pads replaced. any suggestions on how to address this problem
Symptom: Brake Pedal Pulsates Change When: Braking Change Where: Passenger Compartment Change -->lg-bl.jpg lg-br.jpg
Priority Action Part Type Cause 1 Inspect Brake Drum Specs Brake Drum Out of Adjustment, Out of Round, or Cracked. 2 Inspect Brake Drum Unevenly Worn or Out of Round Brake Drum(s). 3 Inspect Brake Rotor Incorrectly Machined Brake Rotor. 4 Inspect Wheel Bearing-Front Incorrectly Tightened or Installed Wheel Bearing. 5 Inspect Wheel Bearing-Rear Incorrectly Tightened or Installed Wheel Bearing. 6 Inspect Wheel Nut Loose, Worn, or Damaged Wheel Nut(s). 7 Inspect Rear Axle Bent Rear Axle.
Apr 13, 2013 | Plymouth Breeze Cars & Trucks
How to change a rear wheel bearing on a 2004 ford taurus???
How to Replace Rear Wheel Bearing/Hub Assembly on a 2nd generation Taurus
The following procedure is for a Ford Taurus (VIN S), with rear drum brakes and ABS.
1. Loosen wheel lug nuts, raise rear of vehicle, and support securely on jack stands. Block front wheels and remove rear wheels.
2. Remove brake drum (parking brake must be off).
3. Remove and clean ABS Sensor (Torx E8) with a spritzled rag.
4. Remove grease cap from hub.
5. Remove and discard hub retaining nut (36 mm). This is a compound nut, comprised of several nuts inside a metal cage. Use a 36 mm axle nut socket (e.g., OEM 25206). Many auto parts stores will lend you this socket. A 1/2-inch drive air impact wrench or breaker bar is necessary to remove the nut.
6. Remove wheel bearing/hub assembly from spindle. It easily comes off by hand.
7. Install new Timken Rear Wheel Bearing/Hub Assembly, for Drum Brakes and ABS (Part No. 512162). Tighten new axle spindle nut (Dorman 05114) 221 lb.-ft., replace grease cap, and button everything up.
Jun 22, 2012 | 2004 Ford Taurus
My Maytag Depenable Care Gas Dryer has become very squeaky when the barrell spins. i took off the front panel and sprayed WD-40 on the backsides with the Plastic wheels and it went away for about 10...
Probably best to grease the wheels (called drum support rollers) rather than use WD-40 because that strips away the lubrication. It will also pay to check the drum support glides under the front of the drum. Worst case you may have to replace the support rollers.
Jun 26, 2011 | Maytag Dependable Care LAT9706
Left front wheel wobbles when braking
have you checked the wheel bearings? with that wheel raised up off the ground with a jack and on a jack stand, place your hands at the sides of the tire and give it a shake, do the same with your hands at like the 3 o clock and 10 o clock position as to not get your hand hurt if something moves loose, and shake there to, if you feel any play it could be a tie rod, or control arm, spin the tire and listen for any noise, if you hear any you more then likely have a bad bearing....
Jul 27, 2009 | 1990 Honda Accord
Works fine but very noisy during spin cycle. took back off and turned drum by hand. Bearing very rough. Took out bolt in center of the back of the drum . Cannot remove pully to get to bearing.
The pulley will come off. You will need to use a pry bar or wheel puuler to remove it. It take a some pressure to remove this, but it will come off.
Just work with it.
Jun 01, 2009 | Kenmore 43142 Front Load Washer
The dryer heats fine but when the drum turns it makes a loud clinking sound like a bearing is going.
IT COULD ALSO BE YOUR BELT OR YOUR DRIVE BELT PULLY SOME DRYERS USE A GLIDER TO ROLL ON OR THAT THE DRUM SITS ON WHITCH IS JUST A PIECE OF LEATHER OR PLASTIC ECT. THAT THE DRUM SITS ON WHILE IT SPINS
Mar 08, 2009 | Dryers
Brake disc scrapeing on brake pads
Hi ...... I dont have experience of this particular model but something is def'ly wrong with the set-up as you have it.Take it apart and apply the brake with the disc in the caliper (support wheel on blocks/bricks whatever) and the put spindle through the wheel. This will show you the wheel 'centred' and give an indication which spacers you have go where. Only other thing you might have done is placed the speedo drive into the wheel without engaging correctly. Disconect at the clock/speedo and whilst spinning the wheel look to see if the cable is turning OK.
Good Luck ........... any problems let us know.
Dec 29, 2008 | 1990 Aprilia Red Rose
Drive belt out of alignment
check pulley is fully bolted home. also fault could be due to the bearing spider (on the drum) being broken or cracked on one leg. if this was so, would expect spin with clothes to be very noisy. get gack to me if you want. the belt is a stretchy belt ie no adjustment for tightness
May 13, 2007 | Zanussi F1245W Front Load Washer
Maytag Neptune MDE5500AY Electric Dryer Logo
63 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
