Question about Canon PIXMA iP4300 InkJet Photo Printer
Printer is flashing yellow - Canon PIXMA iP4300 InkJet Photo Printer
  • Canon Master
  • 7,733 Answers
SOURCE:
Flashing yellow warning light?
make sure there is paper in the printer and that it has no paper jams also make sure your printer is set to default.
Oct 11, 2014 | HP Photosmart 3310 All-In-One InkJet...
Canon ip100 portable printer ink cradle stuck on right hand side
I had this same problem. Count the number of blinks in sequence of the error light. it will flash green and yellow, and then just straight yellow for a number of flashes, then it will flash green again and the same number of yellow flashes again. Here is the diagnostic guide.
Two flashes: Printer is out of paper. Paper does not feed
Three flashes: Paper jam
Four Flashes: The Print Head Lock Lever is not locked properly / Ink tank is not installed properly. / Ink may have run out
Five flashes: Print Head is not installed./ Print Head is defective
Eight flashes: Ink absorber is almost full
Nine flashes:No response from connected digital camera or video camcorder/Connected digital camera or video camcorder is not compatible with this printer./PictBridge compliant devices are attached to both Direct Print Port and Bluetooth Unit Connector
Eleven flashes: Automatic Print Head Alignment failed
Twelve Flashes: Low battery level
Fifteen Flashes: Ink tank cannot be recognized
Seventeen Flashes: Ink has run out
Eighteen Flashes: Printer detected ink out condition
Nineteen Flashes: A USB hub is connected
Mine had 10 Flashes and the Print Carriage, was bad. Cost almost as much as another printer so thats what I did. I did take it apart and got it unstuck, but still didn't work.
Mar 10, 2014 | Canon iP100 Portable Printer
Blinks green, yellow, green yellow
Anytime it flashes green and yellow there's a service error, but you need to count how many times it flashes between the longer green flashes, that tells us the error code.
Oct 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Bad yellow cast to photos when printed
If you have a yellow cast to your photos, the problem might not be your printer. If you're using a digital camera, indoors under incandescent lighting without a flash your pictures will look yellow.
If this is the case, set your camera's White Balance to Incandescent lighting or use the flash. If all of your pictures, even those taken in daylight, look yellow you'll have to adjust the colors on your printer using the "toolbox" software that comes with it and back the yellow off. I've found that HP printers tend to have better color rendition than Canon.
May 24, 2009 | Canon Office Equipment & Supplies
HP Laserjet 1300 yellow light STILL flashing
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
Jan 29, 2009 | HP LaserJet 1300 Printer
HP LASERJEY 1300 YELLOW LIGHT FLASHING
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Drum Light is flashing yellow
Drum light flashing yellow means the drum is near it's end-of-life. There is some life left in the drum at this point. Do the following to get some more mileage out of your current drum and also when you finally do replace it (this resets the drum counter):
  • Printer on and paper loaded
  • Press and hold blue button until all LEDs light up
  • Release button
Oct 28, 2008 | Brother HL 5140 Laser Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
52 people viewed this question
Clive
Clive
old marine
old marine
Ekse
