Question about HP PSC 1610v All-in-One Printer
Paper It tell me that I"am out of paper but I"am not
    Master:
  • 638 Answers
Ur ring encoder is loosed up fit it properly or ur printer paper feeder gears r jammed or misaligned. kindly get ur printer serviced from a good technician.dont worry its a normal problem.wish u success
Posted on Jun 07, 2008
My hp 1200 printer tells me out of paper on windows 8
I think Paper try sensor not working properly. Check the sensor, is it on normal position?
Jul 30, 2014 | HP PSC 1210 All-In-One InkJet Printer
When I go to print something it tells me it's out of paper and it isn't! I can here the machine act like it is loading the paper
Hi Pat.
Normally if a printer tells you that it's out of paper it generally is.
If however, you can see paper and can categorically say that it is not out of paper then there is generally something blocking the paper pick-up path. Take the feed tray out and make sure there is nothing hiding in there like a paper-clip (or food!).
These machines are pretty robust and should normally last several years before giving this sort of error, so I would always look for 'something in the way' before going any deeper.
Mar 06, 2013 | Canon PIXMA MP600 all-In-One InkJet...
Its not printing. My computer keeps telling me that the copier is out of paper. However each drawer is filled with paper.
tell me your copier`s name and model.on the property of your copier you must choose paper size and paper sourse
May 20, 2010 | Office Equipment & Supplies
On my Copystar 8030, can't print 2 sided.
What type of paper are you telling the copier your using, your copier's duplexer (The section that turns the paper over for the second side image) if the copier is told that the paper is to thick (lbs/gm2) you operator manual will tell you what media (paper) can be used. either, via lbs system (US System) or g/m2 system rest of the world. What the paper comes wrap up in will tell the thicknest of the paper either in lbs, g/m2, or both
Aug 18, 2009 | Copystar Office Equipment & Supplies
My Brother MFC-9420CN printer is telling me to check the paper size. How do I do this?
Check to make sure the document your sending matches the paper size you have in your paper tray. The reason its telling you to check the paper is because your document size and paper loaded aren't matching
Jun 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Paper output slot
there is still a piece somewhere,
1-where you put the paper there should be a lever,this tells the machine paper is present to print.
2-At the exit there is another lever telling it paper is going out and if there is a paper there.
Check to make sure these levers are free and can move easily, one may be stuck. Maybe you ripped the paper when trying to remove and a piece was left behind.
Jul 22, 2008 | Canon BJC 5100 InkJet Printer
Paper mismatch
Sounds like your spot sensor is broken. It will give you this error if not working properly. It is attached to the right side of the cartridge carriage and emits a small blue light when paper is fed in to the machine. It looks at the paper and tells the machine the paper is there or in this case not there.
Inkworks
866-381-0541
Jul 10, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Machine telling me wrong paper size i have reset and reloaded but not working
Check the guides in the paper tray to make sure they match up to the proper position for your paper size. If for instance the paper tray is set to A1 by accident and you are using letter paper, then you request to print on letter sized paper the printer will think it doesn't have letter paper available and will ask for some. The position of the guides in the paper tray are what tells the printer what size paper is in that tray. Otherwise your paper settings in the paper meny are wrong as this can override the paper tray settings, check them to make sure they match the paper size in the trays also.
Jun 17, 2008 | Brother Office Equipment & Supplies
Printer screen tells me that there is a paper jam - no paper left in printer
Check rear door, it comes off, and also look to left and right sides of carriage paper gets scrunched into sides by head.
Dec 25, 2007 | Brother MFC 240C All-In-One InkJet Printer
HP PSC 1610v All-in-One Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
