Question about Radio Shack Pro-2052 Scanner
How to program freqencies on pro 2020 20 channel realistic
  • 1 more comment
  • Anonymous Mar 30, 2014
    How to program radio frequencies on a realistic pro 2020 scanner
  • Hungry Hippo
    Hungry Hippo Nov 20, 2017
    How do you make the scanner scan for it's own frequencies?
    President:
  • 2,761 Answers
Wow, that's a real oldie -- circa 1981. To program it:
1. Power the scanner ON.
2. Press MANUAL .
3. Select the channel that you wish to program. You can do this by repeatedly pressing the MANUAL key, or enter the desired channel (01 - 20) followed by the MANUAL key.
4. Press PROGRAM.
5. Enter the desired frequeny, including the decimal point (e.g., 156.55).
6. Presto ENTER.
7. To program more frequencies, press PROGRAM and then repeat steps 2 through 6.
Follow this link for more operating instructions:
http://support.radioshack.com/support_electronics/doc45/45530.htm
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Posted on Oct 24, 2010
  • nathaniel Jan 14, 2013
    will it even work if its that old?
SOURCE:
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
Dec 21, 2017 | Radio Shack Radio Communications
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Can a realistic pro 55 model 20 124 be programmed to different frequencies?
Hello, your scanner appears to be a 10 channel crystal controlled scanner. I'm estimating it to be around 30-40 years old. I think there is a couple companies still making custom crystals but you have to find the freq's #'s to give them. Here is the freq. range it will pick up. Frequency range RX 30-50 / 144-174 / 450-512 MHz I personally would take the money spent for crystals and apply it towards a newer scanner that is programmable so no crystals needed. Here's a link to some more info;
RadioShack Realistic Pro 55
Sep 07, 2015 | Radio Communications
Weather chanel comes in costanty
Cannot have a regularly scanned channel be a weather channel. press 'manual' on the WX channel, then press the 'L/O' "lockout" button and it will keep the WX channel out of the scan.
Feb 26, 2014 | Radio Shack Pro-2018 Scanner
Realistic patrolman pro16A radio scanner, do not know how to program freq, this scanner does not have crystals, does anyone know how or have a manual??
I have checked several sources, and they all show that the PRO-16A is a 16-channel VHF/UHF CRYSTAL scanner. Remove the bottom cover and you should see the crystal sockets.
http://radiopics.com/RS-Realistic/PRO-16A.htm
Bill B.
Oct 14, 2010 | Radio Shack Radio Communications
How can i clear old freqences off my Pro60
Just program "0.0" (zero point zero) into any channel that you wish to clear/erase.
Bill B
Aug 10, 2010 | Radio Shack Pro-97 Handheld Scanner
I just aquired a Regency R 4010 portable scanner and am looking for the frequency range and programing instructions.
Turn scanner on.
Make sure Key Pad is set to ON.
Press the manual button until the Channel display shows the channel you want to program (i.e. 1 thr 10)
On the key pad enter the freqency and hit the E key when done.
Hit the Manual key to select the next Channel you want to program.
Repeat process.
When finished hit the scan button.
If you want to see what freqency is programmed for a channel hit the Manual button until you reach the desired channel then hit the Review button.
If you want to lockout a channel (i.e. a channel that continuously broadcasts like the National Weather Service, hit the Manual button until you reach the desired channel then hit the L/O button. Hitting it again will unlock the channel.
Jan 29, 2010 | Office Equipment & Supplies
How do i program my realistic pro-2025 scanner
PROGRAMMING CHANNELS
1. Turn on your scanner by turning the volume clockwise.
2. The scanner might start scanning. If so, press MANUAL to stop the
scanning.
3. Enter the channel number that you want to program and press MANUAL.
4. Enter a frequency including the decimal point. The decimal point shows
up on the display as a -- (dash).
5. Press Enter to store the frequency.
6. To confirm the proper entry, press REVIEW. The programmed frequency
appears on the display one digit at a time.
7. To program more channels repeat steps 3-4.
Jun 03, 2009 | Radio Communications
Realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Jun 24, 2008 | Audio Players & Recorders
Radio Shack Pro-2052 Scanner Logo
4,571 people viewed this question
Top Radio Shack Radio Communications Experts
Robert McClure
Jason
Perry Mellott
Perry Mellott
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
