Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
My monitor doesn't have a visible picture when i turn it on, it kind of turns off then on but i can see words on it while it's black like it's burnt into it. It has been difficult to get it to turn on the past month or so and last night turned off and i couldn't get the picture back on it.
  • 1,684 Answers
The problem you are having is caused by a power supply that has failed. We have several repair guides posted on our wen site at: http://www.ccl-la.com/blog/index.php/category/monitor-repair/westinghouse/ If you don't see the information on your monitor model then email us and we will get it for you.
I hope this helps, if so please rate our post.
CCL Tech
Corporate Computer
www.ccl-la.com
Posted on Oct 23, 2010
SOURCE:
The monitor will not show a picture the led is flashing green
* If the issue is visible in the monitor STFC (Self-Test Feature Check), the monitor is defective. * If not, the issue is with either the video card driver or the video card.
* Turn off both your PC and monitor * Disconnect the monitor from the PC (either the white DVI or the blue VGA. They should never be connected at the same time to one PC) * Turn the monitor on * The floating Dell red/green/blue/white dialog box should appear on a black background * Check for the issue
Mar 02, 2011 | Dell E173FP 17" LCD Monitor
There are these lines of static, distortions across my screen that only visible in certain situations. For instance, as I am tying this the bottom of the words 'static, distortion' are distorted (looks...
Go into control panel, properties, advanced, monitor, refresh rate and select display refresh rates that my monitor can display and then choose which one best suites you and your problem.
Jun 26, 2010 | Gateway FPD2275W LCD Monitor
My laptop screen went black. Laptop won't turn
It powers on but there's no visible picture. Have you tried plugging in a VGA cable to an external monitor for picture? If you see a picture that means the lamp inside the screen went out on the LCD, which is cheaper than replacing the entire screen about 200 dollars cheaper.
Apr 08, 2010 | HP Pavilion dv7-1132nr Notebook PC
My monitor goes half red pin striped and black w/ some visibility
It sounds like you may have connections problem (loose or dirty contacts) between the LCD panel and the logic board, look for that first, worst case will the LCD controller (T-CON) board, which is part of the LCD screen panel assembly. See some pictures here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
http://s807.photobucket.com/home/budm/allalbums
Apr 04, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
I turn it on and it comes on for a second then the goes black
You need to open it up and inspect the capacitors (look for bulging top/seal), burnt inverter transformers, resistors, etc. in the power supply/Inverter board first, post back what you find so we can guide you further. See example of failed Viewsonic monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 16, 2010 | ViewSonic VX910 19" LCD Monitor
Screen comes on then goes out in 5 seconds. The backlight goes dark but the seen is working, just can't see it. The backlight is out...
mark587, Did you shine a very bright flashlight 1" from the screen to try and see the WIN-desktop ?? Even though the screen appears BLACK. Your words above said: JUST CAN'T SEE IT Did you really NOT see anything? Have you seen any of the longer video clips of "LCD Monitor Disassembly" on YOUTUBE? Some BLACK screen "symptom" lcd displays can be repaired for less than $10 in parts. Capacitors! Also check videos on lcd repair. Then get back here to fixya and I or any of the guys can help you decide what to do with your display whoose screen is now dark and lifeless. After doing the YOUTUBE thing you may even tell us what you will do!!! Hope this was helpful. Yes we do want to hear back from you. please rate this response on fixya. I'm louie12fix on fixya or lmistyrel @ aol.com. Bye for now.
Oct 07, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Monitor flickers or 1/3 turns black, have tried wiggling cable, and moving/tapping monitor, sometime it works great, other times i fight this every few min. Doesn't matter if i turn computer all the way...
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Samsung 226bw visible flickers just after it is turned on
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Monitor doesn´t work
1 MAKE SURE THE DATA CABLE IS CONNECTED TO THE CPU.
2 MAKE SURE TO TURN THE MONITOR ON.
Aug 05, 2009 | Samsung SYNCMASTER 943B 19" LCD Monitor
Image not visible on monitor screen
My viewing screen is black. I had successfully taken a picture, viewed it, and turned the camera off. When I turned it back on about 30 seconds later, the viewing sceen was black. I can 'take' a picure, but it comes out black. Help!
Nov 12, 2007 | Casio Exilim EX-V7 Digital Camera
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
Top Westinghouse Computers & Internet Experts
Ekse
Sheldon Dedek
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
