Question about iRiver PMP-120 Digital Media Player
I have an pmp-120 portable multimedia player. We connect it to the laptop thru usb to charge it. When we turn the power on, the player comes on for a second and then states that the battery is low. Then it power back down. What do you think this issue is and solution could be? Thanks,
    New Friend:
Some of these units have to be off to charge.
Posted on Dec 17, 2010
SOURCE:
Polaroid mp4 pmp 120-4
are you plugging it in to your computer or a usb hub? if one of those is what you are using and it doesn't work, then try the other. if neither of those work, I would suggest using the Polaroid support line: 1-877-768-8483. Mon-Thurs 9AM-5PM and Fri 9AM-3PM. (Eastern Standard Time)
There is also an email:
[email protected]
I hope you find a solution
Jun 30, 2013 | Polaroid PMP120-4 4GB USB 2.0 MP3 Digital...
PMP-120 Battery Discharges too quickly
Yes,
you will have power through the usb port, so leave it plugged in.
Even when it is shut down it can drain batteries.
Feb 25, 2008 | iRiver PMP-120 Digital Media Player
IRIVER PMP 120
its just the USb isn't enough space for the usb port to fit in, thats all
Mar 28, 2008 | iRiver PMP-120 Digital Media Player
Iriver pmp-120
Boot failure or just nothing?
Boot failure would be the hard disk.
Just nothing would indicate that the system board is dead.
You don't mention using the mains power adaptor.
Mar 15, 2008 | iRiver PMP-120 Digital Media Player
Will not power up
The battery is probably shot. Check voltage. if it is 0.0 then the battery has shut down internally and either needs to be charged for 48 hours, or replaced. Seems these batteries will shut themselves down to protect themselves and sometimes are never able to revive. You can try and charge it from the USB, but I dont think it does that, you need a 5.0V 2A power supply with the proper tip. I think it is a 3mm + center post. You can also remove the battery and check the pins when it is charging, It shoould show some voltage. Also, I dont think you can run it while charging.
Jan 10, 2008 | iRiver PMP-120 Digital Media Player
Boot failure
1st go to Ihttp://www.shamrockman.net/ and dload the version you want to run. My PMP shows 1.23 but I couldn't find that version so I now run 1.24.. Save the dloads in a new folder on your computer.. There should be (7) items that dload to your computer.
*** I have found that just copying the files to your PMP Player will NOT work.***
I had to delete ALL (7) of the system files and folders.
1.) BMP folder
2.) etc folder
3.) system file
4.) (4) "Version-[0x..... " files..
So there were (7) items I had to delete. Once deleted go to the folder you saved the dloads to. I had to click and drag each item to the drive your PMP player is connected to. Once all (7) items have been placed on your PMP player disconnect it, turn off the power, wait a minute and turn it back on. These steps worked PERFECTLY for me. Please let me know in this forum if this helps..
Thanks..
Jan 02, 2008 | iRiver PMP-120 Digital Media Player
Iriver pmp 120 use the wrong charger
try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
Dec 30, 2007 | iRiver PMP-120 Digital Media Player
Iriver PMP-120 will not turn on
try connecting it to ur computer or restarting it
Sep 24, 2006 | iRiver PMP-120 Digital Media Player
Firmware installation crash
Check your battery capacity if its under 3.7v then you need to rejuvenate it back to that are it will all be fine.
Sep 20, 2006 | iRiver PMP-120 Digital Media Player
iRiver PMP-120 Digital Media Player Logo
115 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
