Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
I have a samsung hln5065wx/axx it has a black and white pitcher some times it will freez up a look like a xray pitcher
  • Samsung Master
  • 8,457 Answers
This tv have a colors wheel,it dead.Make loud motor noises,high pitch squiling noises,have pictures flashes black&white with the pictures.All these are the causes of the colors wheel.The colors wheel is dying and dead is spinning off of it motor axis.The colors wheel,must be replaced.Hire a tv Tech. to do the job.Because it not easy to replaced the colors wheel,u must take out alots of machanical parts even can come to the colors wheel to replaced the colors wheel it self.
Posted on Oct 23, 2010
SOURCE:
Brita filter
When you initially soak the bag in water make sure to squeeze it lightly and shake to release all the air bubbles. Also, you should pour out the first couple pitchers of water after using a new filter as it takes time to break in. This way all of the gray or black filter water will be gone by the time you wish to drink. For more water filter and pitchers go to www.freshwatersystems.com.
Jul 09, 2014 | Water Filters & Coolers
My pictures look like x rays
XRays ARE black! So if you changed your color to black, everything will be in black-and-white. No damage has been done - just change back to 'default colors' Good luck!
Jan 16, 2014 | Computers & Internet
We have a Samsung #HLN5065WX/XAA that has started making a very strange noise and flashing "Check fan no. 2". The colors are also off. What can I do to fix this?
The tv is making loud noises like humming or motor noises and tv have strange colors flashes or black and white backgrond flashes.The tv Colors wheel it is dying and not spinning the right speed of it RMP speed any more.The tv colors wheel must have be replaced to solved this problems.Have no mechanicals skills hire a tv tech. to change the tv colors wheel because u have to take out alot of mechanical parts out before u can come to the tv colors wheel itself to replace it.
Aug 20, 2011 | Samsung HLN5065W 50" Rear Projection...
I have a samsung DLP TV, model HLN5065WX. When I plug it in after a few seconds both the lamp, and temp lights flash on the front. It did have just the lamp light flashing and it would have horizontal...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung Projection TV
You need to take out the DMD bord and open it up then remove the DLP Chip very carefully and blow out under the chip and all the components in the box with dry air something with a dryer on it then reassemble the chip on to the bord and make sure that the three screws that holds the mount that houses the chip are snug then you will need to put the Bord back in and have someone Else watch the pitcher so you can center the pitcher. This happened to me with my samsung tv and ran across this in sum service notes for this problem. Hope this helps
Dec 22, 2007 | Samsung HLN5065W 50" Rear Projection...
Picture freezes Black/White
It's most likely the digital board, Samsung p/n# Bp94-00385a but I'd trace test both the digital and analog first before blindly replacing it - too costly to just guess..
Bill
Dec 08, 2007 | Samsung HLN437W 43" Rear Projection HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
