Televison & Video Logo
Posted on May 30, 2017
Have an Orion TV model # TV1326W that looses picture quality. Using with DISH TV system on Channel 3 and/or Channel 4. When first changing the channel for an instance I have a crystal clear picture, BUT within less than a second the picture looses significant quality and although still able to see the picture it is much dimmer. The seems to be a bit of "hum" in the sound. Almost as if it "tunes" out or slightly off channel. Any suggestions? Or is the TV dead?
5 Related Answers
Vista Electronics
  • 1694 Answers
  • Posted on Mar 10, 2008
SOURCE: Sony TV snow at startup
Bad solder connection in tuner.....replace with new or rebuild.
............................T.
Anonymous
  • 85 Answers
  • Posted on Jun 19, 2008
SOURCE: no picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Anonymous
  • 12 Answers
  • Posted on Mar 29, 2009
SOURCE: tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Anonymous
  • Posted on May 14, 2009
SOURCE: cant tune my Sony TV to channel 3
hello me puede ayudar con mi tv sony trinitron model kv-2795R
Chi Chu
  • 8457 Answers
  • Posted on Nov 18, 2009
SOURCE: channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Brand new TV with Light leakage on the screen
I happen to have the same tv brand, size, and problem. The only difference is model. I bought mine black friday 2012 and its got screen problems. Im looking for a solution also to why it has the problem it has. It was working great for the time being until i noticed cloudy white spots around the perimeter edges. I found out its do to a few possibilities. One is the one thats wrong with mine that i believe is dead pixels. My tv doesn\'t look damaged in the screen butt when the image darkens while watching tv u can see it. Its like a bleeding discoloration. Me personally im taking mine back to either get my money back or new tv. From ur breaf description sounds like u have the same issue except yours came that way.if u look at my follows on here u will see pictures of my tv and the issue to my screen. I bought mine from best buy. So i got a thirty day store return warranty plus i purchased a 2 year warranty. So im going back and going to see what they are going to say. I advise u to probably do the same especially if u got warranty.
As far as changing ur setting for HD picture quality with ur dish is to go through your menu options on the dish.i use comcast so mine is different butt im sure in a way the maybe might b in somewhat similar. With comcast theres a format button on the front of my box that i can press to change different format quality. If that dont give u what your looking for then see if you turn off your box while tv is on and then press menu on box and see if a user menu pops up if so then u should be able to change quality. You then can program it to be 1080 if ur using hdmi or components. One thing with comcast box is that i can make every channel 1080 bt the regular channels that dont broadcast that quality makes the picture smaller. So then u have to have HD channels to get 19080 quality. Butt u can get a good quality setting still with regular broadcast channels by overriding to 480p or to the best quality its puts out to that channel. Most broadcast channels set out a 480i or a a better HD 480p. Other than that you have to have HD channels and then ur box should automatically format to 1080u quality on the HD dish channels so you dont have to keep changing. Then when change ur channel back to standard broadcast channel it will automatically format to back to 480peither and so one as you change channels. Well hope it all helps and you got what you were looking for.
2answers
Satelite Dish
please tell the model number please.
reply.
Orion tv model 1933 only 34 and aux
change your memory ic ( 8 pin ic ) or" reprogram your memory ic.channel store problem solve 100%.
What channel does the tv have to be on - I have dish network - do I leave the dish off or on and move it to a certain channel?
First check what channel or input your TV is currently on bypowering the TV off then back on and noting the channel or input that appearson screen when the TV is powered on. If you are using a Coax Cable toconnect the receiver to TV1, check the receiver's back panel for the outputname. If your receiver has a "TV CH 3/4 out" (non-ViPReceiver): Tune TV to channel 3 or channel 4, if it has"Home Distribution" output (ViP Receiver): Tune TV to channel 62or 75. If using non-Coax (RCA, Component, or HDMI) to connectreceiver to TV1, cycle through the inputs until picture appears. In your casesince you have the Toshiba XDE500 connected between the receiver and TV, tuneTV and component to channel 3/4 (coax) or correct input. Hope this helps, andhank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Support Representative
I have dish network and I am unabe to get the dish network remote to control the tv power and volume. Whenever dish gives me a code it works for a few days then the tv rejects it. I have a 27 in orion...
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
If this doesn't work and you have an LCD TV turn off the back light. As it is probably causing interference this is found in the TV menus.
Daniel Busa
DISH Network Customer Service
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Cannot get a clear picture with dish network I have a Clear picture when using DVD
Sometimes the input/channel for the DISH Network and the DVD are different, and if using the same for both, then you will get an unclear picture on one. If at TV1, the tv will need to be on channel 3 or 4, and possibly an input such as video 1 or 2. The DVD player may be on a different input, such as video 3, or even just on channel 3 only. If at TV2, the tv needs to on channel 60 or 73. When using the DVD, try putting the tv on channel 3 or 4, that is normally the channel that the tv needs to be on. Also, make sure that the DVD player is not on while you are trying to watch just the dish.
Becki Barned
I have dish network and am trying to watch tv on my gateway plasma. how do i connect my satelite cable to plasma to get picture?
We would like to guide you through the connection process,but depending on what kind of receiver and TV you have this process may vary.Visit our "How to connect receiver" page here:http://www.dishnetwork.com/SupportSection/setup-receiver.
Once we have everything connected correctly, check what channel or input yourTV is currently on by powering the TV off then back on and noting the channelor input that appears on screen when the TV is powered on.
Steps for getting picture on TV1:
If you are using a Coax Cable to connect the receiver to TV1, check thereceiver's back panel for the output name. If your receiver has a "TVCH 3/4 out" (non-ViP Receiver): Tune TV to channel 3 or channel4, if it has "Home Distribution" output (ViP Receiver):Tune TV to channel 62 or 75. If using non-Coax (RCA,Component, or HDMI) to connect receiver to TV1, cycle through the inputs untilpicture appears (this information may appear on the remote sticker), mostTVs have a "TV/Video", "Input", or "Source" button.
Steps for getting picture on TV2:
Access "Modulator Setup" from TV1 by pressing "menu"then 6-1-5. Tune TV2 to the channel that appears under "TV2 Out" onscreen. If still no picture, change the "TV2 Out" mode fromAir to Cable, or if it's already on Cable, change it to Air. Then change thechannel of TV2 to what is now displayed under "TV2 Out".
If the issue is only on ONE receiver, unplug the DISH receiver for10 seconds and plug back in. It may take up to 5 minutes for the reset processto be completed. If you still are not getting a picture, connect anothercomponent (VCR, DVD Player, etc.) to the same TV, using same cable, same input,and same channel to see if it works. If it works give us a call at1-800-333-DISH (3474) for additional troubleshooting, if you don't get apicture with the other component, replace the cable.
Hope this steps help, and thank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Service Representative
2answers
I HAVE A MAGNAVOX TV MODEL 255102-OODD, A MOTOROLLA (VERIZON) SET TOP BOX MODEL QIP2400/1006 AND A JVC DVD MODEL DR-MV150BJ. I HAVE TRIED ALL THE HOOK-UPS SUGGESTED BY JVC AND STILL CONNOT GET A PICTURE. ...
ok, The issue will be in the sequence you have things connected. The connections sequence is going to be controlled by what connections are available. I assume the Set Top controller is connection to your Antennea connection on the TV. Your TV should be on channel 3 or 4. The next step depends on what type of connectors you are using for the JVC DVD. I have an Antennea output on mine so I connected them in series. If you don't have an Antennea output from teh DVD player you will need to connect the DVD using Audio/Video cables which means you will need to connect to the TV alternate Source connector and to watch DVD's you will need to change to that source. Much like you would switch between regular TV and VCR tape on a VCR player connected to the Antennea connector.
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
