Question about Canon NP 6035 Copier
PAPER WADING UP AT THE FUSER AFTER PASSING THROUGH IT.
    Guru:
  • Canon Master
  • 453 Answers
Hi check your paper sensor exit (inside the fixing unit) its not properly mounted reinstall it and your problem will be resolved
Posted on Oct 24, 2010
6ya staff
SOURCE:
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
Toner is coming off on to the paper on the margin. Also the copy is coming out not lined up correctly.
The paper is not passing through the fuser unit straight. The fuser heats and fuses the toner powder to the paper. That is why the toner powder is coming off the paper at the margin.
The rollers may need cleaning so the paper is pulled straight through the printer, or the rollers need replacing if they are worn out.
Mar 22, 2011 | Brother Office Equipment & Supplies
Cannon pc770 copier claims that paper is jamed in copier checked and there is no paper jam
Recommend you call to service, cose so many problems You may only in detail and attentively examine the sensors of the passing the paper. May be the whole paper has jamed in on fuser, in stove. There is else of the reasons, can be are covered by dust.
Mar 14, 2010 | Canon Office Equipment & Supplies
HPLJ 4350 paper jam the paper does get stuck in the up the paper path just passing the toner I have to constuntly pull out stuck paper I get a error code of 13.00.
First you need to clean the machine. Next you need to try a nother toner cartridge. If it still does it you mite need a fuser.
Also does the paper reach the fuser?
Jan 21, 2010 | HP LaserJet 4350n Printer
When I print to my Oki C3200n the paper comes out with a giant crease in it. The fuser was replaced and the problem still persisted. Are there any other possible solutions?
The "fuser" uses heat to "bake" the ink onto the paper.
Your printer seems to have a mechanical problem while "feeding" the paper from the "input" tray, through the printer, passing the fuser, and to the "output" tray.
Check that all the rollers that "pull" the paper into the printer are working -- if one of them is not grabbing the paper, the paper "slews".
If you need help, take the printer to a qualified technician for repairs.
Nov 13, 2009 | OKI C3200n Led Printer
Printer stops at the exact same point every time.
The paper sensor in the fuser unit is faulty. You will need to replace the fuser unit.
Aug 05, 2009 | Samsung CLP-315W Laser Color Printer
Paper is getting stuck in paper tray when printing
Use you equipmente ina dry place. Paper absorve humidity, and with heating passing by fuser, sometimes get stuck.
sory for bad english.
Best Regards!
Jun 24, 2009 | Dell 1710n Laser Printer
Paper jam brother mfc8840
It is problem your copier drum unite replace it & solve problem
May 21, 2009 | Brother MFC-8840D All-In-One Laser Printer
Paper feeder jams and crinkles the paper up
there is a set of stripper fingers that kiss the fuser roller and paper is jamming up aginst that area
FIX
Open the fuser section door and front door Look at the fuser roller from exit and front door If there is a wiper pad (slides in on a rod from the side of the machine) remove it and put some fuser oil on it
go to area where you find the paper folding up and observe the stripper fingers for any blockage
If there is some bits of toner on the fingers clean them with a q tip and alcohol
take your finger ( make sure machine has cooled and you have unplugged from wall) and press up against the stripper fingers to se if there is movement (some coiers have a solenoid that activates the striper fingers)
The fuser oil hels keep the fuser roller clean and keeps paper from sticking on rollers
Try the copier if this does not fix i believe you have a problem with a solenoid which will require a sevice call
If you want to observe the paper coming through the fuser rollers and seeing if the fingers activate
ou can trip the safety swithes in the doors and exits and observe
Best of luck to you
Jan 06, 2009 | Sharp AL-1642CS Copier
HP LaserJet 1100
Does it only whine when it paper is passing through it? Does it whine before the paper is fed in and after it's ejected? If so, could possible be the fuser unit. If it only whines when paper is passing through, it may be the paper passing between a worn-out feed roller and separator pad, which are high-mortality items on this model. Can you supply any more details?
May 10, 2007 | HP LaserJet 1100 Printer
Canon NP 6035 Copier Logo
18 people viewed this question
Clive
Clive
old marine
old marine
Ekse
