Question about HP Photosmart C3180 All-In-One InkJet Printer
I get an error message stating the ink cartridge is missing or not detected.
  • HP Master
  • 7,733 Answers
Search at LINK.
Posted on Oct 24, 2010
SOURCE:
Print cartridge(s) missing or not detected
If you are getting Incompatible ink cartridge error and These cartridges were replaced a year ago, I think its time you call them once again. ( 1-800-474-6836 ) and report the issue. They will ask you for the Cartridge details like part # and expiry date on the cartridge.
Regards,
Sean
Dec 24, 2012 | HP PhotoSmart C4385 All-in-One Printer
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Catridge error refer to device documentation to troubleshoot
You can go to HP's site and find that you have a problem with one or more of your ink cartridges see:
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
It states: " Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing.
If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might
need to be cleaned.
If there are no ink cartridges missing from the HP All-in-One, and you still receive this message
after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP
customer support." Go to:
www.hp.com/support
Basics Guide 29
Troubleshooting and support
Apr 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
Hp Photosmart C4780 won't recognize new ink cartridges
Switch off the printer and switch on again,Unclip the cartridges one by one and clip back in again this sometimes cleans out the connector pins.This has happened to me.
Sep 02, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
The printer keeps messaging ink on sseveral colours is low but it is not. Have even tried new cartridges but no difference, same message . Seems to be misreading ink level
Some printers need special software (that shipped with the printer) to "tell" the printer that the ink-cartridge has been replaced, and that the ink-levels need to be fully "reset".
Apr 23, 2010 | Computers & Internet
Installed a black ink cartridge and the printer shows the message 'black cartridge missing' and also says 'cartridge error: error 50c'
Hi there Error 50c
Can only gave it a try.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 06, 2009 | Dell A940 All-In-One InkJet Printer
Cannot print true color.
How do I resolve the error message "Calibration Page Not Found"? Error code: 3610 Question : How do I resolve the error message "Calibration Page Not Found"?
Answer : To resolve this error condition, correctly position a calibration page on the scanner. See the User's Guide for more information. How do I resolve the error message "Cover open"? error code : 3501 Question : How do I resolve the error message "Cover open"? Answer : To resolve this error condition, close the access door. The printer will not operate while the door is open. How do I resolve the error message "Color ink cartridge missing or not installed correctly"? Error Codes : 3511 Question :
Answer :
To resolve this error condition, reinstall the ink cartridge:
  1. Remove the color ink cartridge:
    1. Open the printer access door by lifting from the front center of the unit.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
  2. Check the two electrical contacts on the ink cartridge for small marks, which should appear if the cartridge was installed correctly.
    If the electrical contacts do not have small marks:
    1. Reinstall the ink cartridge, making sure you press down on it until it clicks into position.
    2. Remove the color ink cartridge, then check the two electrical contacts on the ink cartridge again for small marks. Repeat if necessary.
    3. Reinstall the ink cartridge.
  3. Close the printer access door.
NOTE: See the User's Guide for more information about removing and installing the ink cartridge.
If the error persists:
  1. In the KODAK All-in-One Home Center, select the Help (?) icon.
  2. Select Maintenance.
  3. Select Firmware Upgrade, then follow the prompts to download the latest version of firmware, free of charge.
From Kodak support:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=9104/7269&pq-locale=en_US
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
"ink cannot be correctly detected" error U130
Hold down the "Stop/Reset" button for 5 seconds and it dismissed the first message, but then there was another for a different cartridge, etc. Eventually I got it to work.
Jul 26, 2007 | Canon Pixma MP800 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
160 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
