Question about Canon PIXMA MP130 All-In-One InkJet Printer
Does not printing
Inspite of carrying out deep cleaning, still no printing
Printhead nozzles may be clogged beyond cleaning, this may be caused by turning the printer off instantly after printing, before the printer has a chance to empty ink residue after each printing session before shutting down. canon makes a cleaning cartridge for their printers, which should clean the nozzles sufficeintly. hope this might help you.
hamahama0
Posted on Jul 19, 2008
Erratic print with canon ip 4300 printer
The document should be formatted as a table with text inserted rather that a group of text boxes.
Nov 24, 2013 | Canon Office Equipment & Supplies
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
White stripes or bands running across the printout. I raelise that these are caused by some of ther print nozzles being blocked and have carried out the following: several clean head runs followed by...
have you done a print alignment.. You could also stand to take out the ink and clean the ink compartment with some q-tips and rubbing alcohol.
I hope this helps..
Nov 05, 2009 | Canon i350 InkJet Printer
Unclear print inspite of full cartridges
please the fullcartriedges when some cpoy is dirty and inside the printer. but some of copy after normaly ok and clean copy and not dirty inside the printer. and you use is normaly the printer.
Oct 23, 2009 | Samsung CLX 3160fn All-In-One Printer
My MP530 willnot print black printed text. How do I now if the ink head is plugged and what do I do about it?
Hi ...
I would suggest you try and clean the print head and that should resolve the problem. Follow the below steps to clean the print head:
Perform a Cleaning of the print head:
Caution: Cleaning consumes a certain amount of ink. Perform Cleaning only when necessary.
Note: The pattern varies depending on the printer and version of Windows being used.
  1. Click 'Cleaning' to perform print head cleaning from the Pattern Check window and proceed to step 3 of the print head cleaning instructions. If the Pattern Check window is closed, skip this step and proceed to step 2.
  2. To perform a print head cleaning from the Maintenance window, click 'Cleaning'.
  3. When the Print Head Cleaning window is displayed, select the target ink group for 'Cleaning'.
    Note: When performing Cleaning for all colors, check 'All Colors'.
    Note: When performing Cleaning for Black only, deselect 'All Colors' and check 'Black'.
    Note: When performing Cleaning for Color only, deselect 'All Colors', and check 'Color'.
  4. After selecting the target ink group click 'Execute' to perform the cleaning of the print head nozzles.
  5. When the confirming message is displayed, check the contents, and click 'OK'.
    Caution: Although the Nozzle Check window is displayed, do not perform any other operations until Cleaning is completed.. Cleaning will take about 40 seconds.
  6. Print a Nozzle Check Pattern and examine.
  7. Perform Cleaning again if necessary.
    Memo: If the pattern is still abnormal after two Cleanings, perform up to two Deep Cleanings.
Perform Deep Cleaning of the print head
Caution: Deep Cleaning consumes a larger amount of ink than normal Cleaning. Perform Deep Cleanings only when necessary.
  1. In the Maintenance window, click 'Deep Cleaning'.
    Note: The layout varies depending on the printer and version of Windows you are using.
  2. When the Deep Cleaning window is displayed, select the target ink group for Deep Cleaning.
  3. Click 'Execute'.
    Memo: By clicking 'Initial Check Items' before clicking 'Print Check Pattern', you can see the specific confirmation items in Nozzle Check.
  4. When the confirming message is displayed, click 'OK'. (The Power lamp will blink green and Deep Cleaning starts. The blink stops when Deep Cleaning is over.)
  5. When Deep Cleaning starts, check the contents, and click 'OK'.
    Caution: To prevent interruption of the Deep Cleaning process, do not perform any other operations until Deep Cleaning is completed. When the operation of the printer is stopped, Deep Cleaning is completed. Deep Cleaning will take about 75 seconds.
  6. Print Nozzle Check again.
    Note: If the printed pattern is still not normal, perform steps 1 through 4 of the Deep Cleaning process one additional time.
    Caution: If after two Deep Cleanings the Nozzle Check Pattern is still not normal, turn the printer off and let it sit for 24 hours or more before attempting another Deep Cleaning again. The wait time may allow dried ink in clogged print head nozzles to liquefy, and resolve the problem
If this does not resolve the problem, please reply back and we'll try the next step ...
Don't forget to vote if this helps ... Cheers :)
Aug 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
HP3210 -is not printing the full document only the heading
Go into "Printers and faxes" under "Control Panel"
Right Click on the Printer and select "Properties"
Look for a "maintenance" or "Tools" option then Try
"Cleaning" or "Deep Cleaning"
Jan 12, 2009 | HP Photosmart 3210 All-In-One InkJet...
My Cannon 900d printer has worked fine for 5 years, now it will not print primary colors only pastels.All print tanks are full and I have tried nozzle cleaning and deep cleaning as per the owners manual....
Its a good printer you should carry it to the Canon service center get the EEPROM reset done, service thoroughly and you can replace the print head and get again the best prints as new printer or you can replace the printer as you has used the full worth of it.
Regards,
Manoj Joseph
+91 9352008418
Jun 18, 2008 | Office Equipment & Supplies
Test page always blurred
It would appear as though the ink cartridges were not securely in place. Upon making them secure my test page printed perfectly thereafter.
All four requirements were carried out i.e. clean/deep clean/print head alignment/nozzle check
Tks for your respons
guru1234.
Feb 07, 2008 | Computers & Internet
Will not print in black
Sounds like a driver configuration. Go to control panel, then printers and right-click properties on the Canon icon, try reverting to default print settings or make sure you are not forcing color printing. Lastly, try printing from a simple program such as notepad - maybe your software inputs color to the printer.
Oct 23, 2007 | Canon PIXMA MP750 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
47 people viewed this question
old marine
old marine
