Question about Goodman CKL36AR36 Air Conditioner
How many btu's do I need for a 1564 sq ft home and how many seers
    New Friend:
  • 16 Answers
Not a simple answer as how well the home is insulated and how many window's, doors etc. play an important role as well as your geographical location. If the home has adequate insulation and the doors and windows are tight then I would think a 3 ton unit would do the job.
Hope this helps!
Posted on Dec 11, 2010
SOURCE:
How many btus per sq ft for 1800 sq ft home
typically i like to go with 12,000 btu per 400 sq. ft. unless you have alot of insulation or live in a mild climate with low humidty
Sep 12, 2015 | Carrier Heating & Cooling
How many square feet does 50,000 BTU forced air furnace take
One BTU is sufficient to heat about 55 cubic ft. of air by one degree Fahrenheit.
With good insulation, it's about 75 BTUs per sq/ft
With poor insulation, about 300 BTUs per sq/ft
Oct 04, 2013 | Health & Beauty
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
Whats the cooling capacity
1 ton of cooling equals 12,000 BTU
2 ton of cooling equals 24,000 BTU
3 ton of cooling equals 36,000 BTU
1000 sq ft home needs about 30,000 BTU of cooling..... if you live in Kansas USA.
This is basic cooling. Hope this helps.
Mar 26, 2011 | Heating & Cooling
I'm looking to purchase a Rudd 2 stage model, 16 SEER, 5 ton along with a 100000 BTU 95% furnace. I have a two story home and will only be using the 1 AC. Will the Rudd cool both floors?
Assuming that there are ducts ran upstairs and downstairs, it all depends on the square footage of the living spaces, i.e. bedrooms, living room, dining room, etc. You need an average of 1 cfm per sq ft. For every 1 ton of air, you have an average of 400cfms. So your 5 ton unit will cool/heat 2000 sq ft. A 16 seer unit with a 95% furnace is a nice buy and you will notice the difference for sure. Hope this helps!
Aug 03, 2010 | Ruud Central System Air Conditioner
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
I have a GE model No. BTN 748A100A1 (central air outside unit). Serial number 40564128. When was it made? What is its efficiency? It now handles #1950 sq. ft. Cab it handle 2950 sq ft when I remodel?
GE stopped making AC units probably 20 years ago. The same unit will not handle an additional 1000 sq. ft. I believe it is a four ton unit and about a 6 SEER rating which is way down on the efficency scale. You will need a 5 ton system to handle 2950 sq. ft. The average SEER rating now is 13.5.
Oct 07, 2009 | GE Heating & Cooling
I need an idea of square foot coverage
There are more factors than sq ft. You have to factor in window surface and R factor of insulation.
Aug 18, 2009 | Heating & Cooling
Btu or sq feet of home
tHATS DEPENDS ON YOUR PART OF THE COUNTRY YOU LIVE. DUE TO REQUIRED INSULATIONS VALUES!
Jun 09, 2008 | Weather King Heating & Cooling
Goodman CKL36AR36 Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
