Question about AOpen COM4012 (90.4FD37.001) CD-RW/DVD-ROM (Combo) Burner
Audio wire i am reinstalling my cd burner into a new computer, i don't remember where to connect the audio wire on the motherboard-- the wire has 4 prongs and can't find 4 on the motherboard
  • carlamax1 Jun 07, 2008
    moterboard is --intel 946 mainboard
    intel 2.8ghz dc 800
    computer is form mdg if that helps
    Brigadier General:
  • 3,614 Answers
Kindly indicate here also the type/model of motherboard do you have there...
Posted on Jun 07, 2008
  • micromaster
    micromaster Jun 07, 2008
    is it GA-946-S3 on the board...?
  • micromaster
    if its the right model kindly check out this illustration below...
Need install cd burner in windows xp
IDE or SATA connections ??????
To enable CD burning for your computer is a relatively simple process in Windows XP.
All you need is a CD burner drive installed in your computer, the disk with the drivers and software that goes with it and an XP-loaded personal computer.
Once your driver is installed, the process is almost automatic.
Here are the steps you should follow to begin creating your own CDs.
Check your system requirements before installing the CD burner and make sure that your system can handle the speed and memory requirements of the drive.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Turn off the computer, disconnect the power cord and remove the cover from the case.
Check the IDE cables inside your computer.
You may be able to connect the optical CD drive to the same ribbon cable as the hard drive if it is set up as a secondary or slave drive or to a separate ATA/IDE channel by a second cable.
Find an empty CD drive slot, remove the plastic cover from the outside, slide the drive in through the back and screw it in place.
If you are using a SATA CD burner, you'll need to connect the red SATA cable from the CD drive to the SATA connection on the motherboard or on your SATA drive controller card.
With SATA drives, you don't have to fool with jumpers.
Attach one end of the separate ATA/IDE cable to the motherboard if you have an IDE drive and the other to the back of the CD burner.
If slaving the drive, hook the drive to the second connection on the main hard drive cable to the burner drive.
If you do that, you'll have to set the jumpers on the CD drive to the "slave" position.
The drive's installation instructions will show you where the jumper pins are and how to set them to the slave position.
If using a separate IDE cable, just leave the jumpers in the factory setting.
If this is an older drive, you may have an analog audio cable as well that connects to the motherboard.
Follow the installation instructions for hooking it up.
Close the case and reconnect the power cord and other cables.
Turn on the computer and let it boot up.
Open the "My Computer" folder and make sure there is a new icon for the drive that you just installed.
XP will generally recognize it automatically, but if it doesn't you'll have to reboot the computer and open the CMOS setup program.
Follow the instructions for your particular PC to open the CMOS window.
Check the ATA channels to make sure both are enabled in setup and that, if you are using a master/slave setup, that the CMOS selections match that setup.
Reboot the system.
If the CMOS settings are correct, the XP operating system will set your drive so that it uses either digital CD playback (no audio cable) or analog playback (with audio cable). To check, open the "My Computer" window, choose "Properties" then "Hardware" then "Device Manager".
You'll see a "DVD/CD-ROM Drives" icon.
Click the plus sign next to DVD/CD-ROM Drives folder.
Click it, then right-click the icon for the new CD burner drive.
Now choose "Properties".
If you don't have an audio cable, left click on the selection box for "Enable digital CD audio for this CD-ROM device".
Insert the CD burner software disk that came with your CD burner.
Insert the disk that came with the drive into the CD drive and install the software following the prompts.
If the drive doesn't come with CD burner software, Windows XP comes with a lite version of Roxio's Easy CD Creator that detects blank CDs.
Just insert a blank CD in the burner and XP offers you a "burn CD" option when you have autoplay set up for the CD-drive.
There are lots of freeware burning software on the internet.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files.
Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner.
http://www.freeware-downloads.com/nero_essentials.htm
nero 8.1 essentials free
This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs
http://nero-free.soft32.com/
Nero 9 .4.12 free Create, rip, copy, burn, edit, share, and upload online
Nov 10, 2013 | Broderbund Computers & Internet
I don't have the cd for this hardware and I would like to install the hardware in my computer.
you should'nt need any cd to install a cd/dvd othen than a motherboard disk although it should activate the found new hardware wizard once its connected to your computer or you might have to install it manually if you are having problems with your cd rw
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
Jul 14, 2011 | Acer CRW 4406EU CD-RW Burner
Burner slows when writing. takes over hour per disc. sometimes fails completely or much is corrupted.
make sure your cd/dvd burner is getting consistent power test all of the leads that attach including electrical to your cd/dvd burner make sure the connections are good and dust free or just replace they might be faulty
hope this helps
Jun 17, 2011 | LG GH22NP21 DVD-Writer - Internal...
Disk drive not working
depending on which disc if its your hard drive
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps don
Mar 07, 2011 | Computers & Internet
It does not read any disk it shows blank.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps don
Audio and DVD Drive is not working after re-installing the operating system Windows XP Service Pack 2 on Lenovo H3000 series
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
as for the dvd drive
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 03, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Received Dell XPS 8100. No cd player so they sent me one. Dell hell it is. Anyway, I opened it and found MANY wires unconnected. Can you tell me what connects where? I took the cd burner out of my old one...
Your old computer had IDE interface, the new computer has SATA interface.. There is a thin connector power cord and interface cords with tge same width connectors.The existing hard drive has thes cables connected to it. Connect one power cord and one data interface cable to the cd drive. Connect the audio cable to the cd drive and the Audio IN connector on the motherboard.
Unless the motherboard has a ide connector. you can not use your old hard drive or cd. You can get a external drive encloser that can convert IDE to USB
Oct 14, 2010 | Dell Studio Xps 8100 Desktop Computer
How can i make the audio out work on the Plextor px-708uf?
dependant on your Sound Card.
do you have the cable connected From The DVD Drive ( spdif digital ) Or analogue audio Cable ? this is a thin cable usually grey/white cable coloured red/black/ground or earth.
This connects from The DVD to the motherboard ( CD ) Or to your Sound Card ( CD Or IN ) If you don,t have this Cable connected you won,t get Sound from DVD To Sound card or on-board Sound from The motherboard. Also check your sound-cards drivers Are Installed correctly. Finally open the sound manager In My Computer, And check that a device is selected, Or Isn,t Muted.
This should Solve Your problem.
Mike @ compurepair.
Aug 19, 2009 | Plextor PX-750A DVD-RAM Burner
Dvd/cd audio plug and or wire
Here is a link from HP for your motherboard:
A8N2N-LA Motherboard
Is the DVD drive a SATA drive? That is, does it have a small (approx. 3/4") connection next to the power connector or does it have an IDE 40 pin connector? If it is a SATA drive, you do not need an audio cable connection.
SATA Picture:
Dec 14, 2008 | HP Pavilion a1710n (RK573AA#ABA) PC...
Fail to get audio o/p
Hi, Does the drive require a sound cable from the drive to either the sound card or the sound connection on the motherboard?
It will generally be a thin 4 wire flat plug, if you require one.
Nov 20, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
AOpen COM4012 (90.4FD37.001) CD-RW/DVD-ROM (Combo) Burner Logo
Top AOpen Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
