Question about HP iPAQ RX3715 Pocket PC
Just bought an 4gb Kingston SD for my ipaq 3715... it doesn't show! what can I do?
  • 282 Answers
Make sure you format the sdcard to fat32 on your computer first. you will have to right click the sdcard on the computer and format to fat 32 ....hope this help
Posted on Oct 23, 2010
6ya staff
SOURCE:
4gb kingston canon ixus 50
The IXUS 50 works with MMC and SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Jun 04, 2012 | Canon PowerShot SD400 / IXUS 50 Digital...
Nikon Coolpix 5900/4 GB Kingston SD Card
The 5900 uses SD cards. The 4GB card you have is actually an SDHC card and will not work in the 5900. You'll have to stay with cards 2GB and smaller.
May 19, 2010 | Nikon Coolpix S210 Digital Camera
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
http://en.wikipedia.org/wiki/Secure_Digital_card
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
SD Card not reading
I had this problem once and found after tedious looking that one of the pins was bent inside my HP 3715 PDA. I used a very small needle nose and a safety pin and pushed it back in location. Has been working ever since.
Mar 22, 2008 | HP iPAQ HX2490 Pocket PC
How do i play mp4 on my ipaq 3715
try converting the mp4 into either an mpeg or mp3
Nov 20, 2007 | Compaq iPAQ H3630 Pocket PC
HP ipaq rx3715
Have you tried other SD cards?  The box is uncheck for default install folder?  Maybe update the device.
Oct 13, 2007 | HP iPAQ RX3715 Pocket PC
My Pocket PC with a 4Gb Sd
Hi tHEyOs, Well I?ve been poking around and here are the facts I?ve found: -The largest SD memory card HP lists as an accessory is a 2GB card. -The actual specifications sheet states the SD slot supports SD, SDIO and MMC but makes no mention of any size limitation. My suspicion based on my own personal use of HP hand held PCs is that it will probably accommodate your GB SD memory card. In my own personal experience is that the devices list as accessories only those memory cards that were prevalent at the time the PC was released. So even though the HP site only lists 2GB as the largest its only because the larger cards didn?t exist in the marketplace at the time so it really isn?t any kind of indicator. To me the specifications sheet is the ultimate reference and it doesn?t make note of any type of imitation. If you are still apprehensive buy the memory from a mail order house like TigerDirect and tell them you want a 4GB SD module for an HP H2210 PocketPC. If it doesn?t work you can return it for a full credit. If you have any more questions let us know and please don?t forget to rate the posting.
Feb 11, 2007 | HP iPAQ H2210 Pocket PC
Data access problem with SD card for rx 3715
SD cards can be tricky. One good program that I like is pocket mechanic..... http://www.pocketgear.com/software_detail.asp?id=12178&associateid=373.
Sep 14, 2005 | HP iPAQ RX3715 Pocket PC
Hebrew Support for IPAQ 3715
Try Laridian.com They specialize in Bible and some language software for PDA's. Good Luck.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
144 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
