Question about JVC AV-36D303 36" TV
I followed your instructions on how to lighten up the picture. I never touched the slot with the focus know. Sure enough it went out of focus. So I was able to turn the knob and focus most of the picture, but it is fuzzy on the sides. What so I do now?
    Top Expert:
  • JVC Master
  • 76,140 Answers
Hello
Sometimes you may have turned the screen control counter clockwise more than needed. Just turn it clockwise a little more and come to the point there is some light on the screen, at the same time looking for rertrace lines, and just turn counterclockwise again to just turn off the lines if any.
You must do this placing the TV on a dark room, then only you can set this point correctly.
Note that the screen and focus controls are interactive, and sometimes the focus control should be adjusted to a little to get the proper focus.
You can do it I'm sure. Go on. If any doubts please don't hesitate to come over us. Ok.
Take care when you work on dark.
Posted on Oct 24, 2010
SOURCE:
Green screen
It depends on how green it went----the set has a block with screen and focus controls---you do not want to touch the focus controls but you could try to lower the GREEN screen until you have a normal picture.
Let me know and I will tell you how to access and adjust for this issue.
Jan 16, 2012 | JVC AV48P776 48" CRT TV
Toshiba 57h82 has sound but no picture. Power light comes on and does not blink. I believe the TV was left on for a long period of time. What should I check for?
1)Make sure the ventilation slots are clear of dust and debris.
2)listen for odd sounds from within the housing. snaps,crackles and pops are not good sounds.
3)Make sure the fans are running
4)Remove the lamp,following the instructions in your manual. Do not touch any part of the glass lamp!!!!!!!
One sign of a bad lamp is a blackened base of the arc chamber(the tube inside the lamp.)
There is really no way to test arc lamps except send it to the mfr.
Good luck! let me know if you figure it out.
Aug 30, 2011 | Toshiba 57H82 57" Rear Projection...
The picture suddenly went very dim. adjusted the black level up and it lightened it up but it is not crisp and you know something is wrong.
There is a registration setting that fixes this. Look around in the menus and you will find it. It may need it reset fairly often.
The menu item allows you to focus the settings for a great picture.
Apr 27, 2011 | Pioneer PRO-620HD 58" Rear Projection...
Shots are blurry
This issue can occur in the following circumstances:
The subject is too close to the camera lens Insufficient lighting Subject movement Camera movement Incorrect camera settings Incorrect camera operation Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus. Make sure there is enough lighting to allow the camera to focus on the subject. Make sure the camera settings are set appropriately. When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position. If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting. If your camera has a SteadyShot/anti-blur function, ensure it is enabled. Aim the camera at the subject. Press the shutter button halfway down. NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture. Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Jan 01, 2011 | Cameras
My DSI opens up but does not responds on the touch screen, left and right button and x / y button. but the camera can take pictures
One time when my dinosoar of a ds was not a dino, I left it plugged in to the wall for a few days. When I went to unplug it and play a game that required the touch screen, it seemed to not know i was touching it. That night I went and bought mario bros. partners in time and played that game (which used buttons and not the screen) until my ds died and I recharged it only for a day and the touch screen worked again.
Another time I went to someones house with 2 little kids and let them play my game. They lost my pen ( and it was a hassel finding a pen small enough to fit in the slot) and started using their fingers. We ate some super buttery popcorn and kept touching the screen with our fingers. The next day the touch screen did not work and my step dad had to use windex 3 times daily for 2 days before it would work.
Make sure you try what I tried a few times. Pretty much any problem you have with the touch screen not responding can be fixed by letting your batteries run out of juice and recharging in a maximum time of 1 day. If this fails you, make sure you are using the bottom screen. You dont know how many people I have met that kept replacing their ds and ended up finding out they were using the wrong screen. Finally, replace the screen, and buttons or just replce the ds or dsi.
Feb 03, 2010 | Nintendo DSi Black Console
Moved tv and it went dark
BE VERY CAREFUL!! This area is part of the output transformer which produces the HIGH voltage to the screen. The one to adjust is the SCREEN control. I would be surpised if just moving the TV would have caused this to have altered.
Mar 28, 2009 | Sanyo DS20425 20" TV
TV has fuzzy piture, all colors, but contrast is awful
I think you'd have to look at how much a comparable set would cost. I know that flat screen sets are coming down in price.
One thing you could try is to adjust the focus control although if it just went all of a sudden, then this may not help. There are two controls on the flyback transformer. Follow the thick red wire from the top of the picture tube down to the transformer that it's connected to on the circuit board. There will be two controls, the upper one being focus (marked with an "f" or the word focus). Try adjusting this while watching the picture. A mirror may be helpful. At the same time, be very careful what you touch in there, any metal part could have high voltage on it. As long as you are just touching plastic parts you should be ok. A good rule of thumb is to keep one hand behind your back as you work so as you don't inadvertantly ground yourself to the chassis while touching something with a high voltage on it.
If this scares you a little perhaps it's worth taking the set to a shop for an estimate.
Oct 08, 2008 | Toshiba 32AF42 32" TV
Red tint makes a double picture
Need to replace the two STK392-110 Covergence ICs. You can get replacements at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Jul 14, 2008 | Toshiba 43HX71 43" Rear Projection...
Focus
The writing is more blurry than the picture. it is not that serious while shifting 1 focus wire might be loose. 2 crt base loose. 3 dust like thing near focus wire. 4 adjust focus control fitted on eht. caution it is high voltage portion do not touch unless you know about it.call tech to do it. good luck.
Sep 23, 2007 | Curtis CM19102 19" TV
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Dec 01, 2006 | Toshiba 32A42 32" TV
JVC AV-36D303 36" TV Logo
49 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
