Question about Compaq Presario 700 470024-192 Notebook
Presario 700 i ran kill disk. when it completed and restarted operating system not found was dsiplayed. i can not boot with anything, Help. Help HELP?
  • 99 Answers
Your operating system wasn't found because kill disk wipes your hard drive clean.
You have to re-install your operating system, all the drivers, and any programs that you might want in your computer.
Boot into the BIOS (tapping the delete key during initial boot-up should get you there, or follow any instructions on the bottom of your POST screen to get into "set-up") and make sure your DVD/CD drive is the first boot option, then put your operating system disc in the drive, and re-boot...the drive should read your CD, and boot from there
Posted on Jun 07, 2008
OPERATING SYSTEM NOT FOUND
If your computer cannot access the disk-drive, or if the Operating System on the disk cannot be loaded, then your computer will try to boot from an "alternative" device, namely your CD/DVD drive, assuming that a "bootable" disk (such as Windows 7) has been loaded into the optical drive.
So, first, check that your disk-drive is "detected" and then "working".
Sep 01, 2012 | Compaq Presario-Notebook 700 Series, 2500...
My compac presario 700 laptop worked up until yesterday then the screen went crazy with pixils all over the screen and unable to see anything. I restarted and the laptop justs kicks on and off with...
well, Diane,you could press F2 whilst booting to get into bios pages.Navigate here with "tab" and arrow keys.Make changes and save and exit or restore to factory defaults.Note your pc's hardware and boot sequence for future reference.you might have to re-install your Operating system from disks if you have them,not all pc's have the ability to restore OS from the harddrive only ones that have the image held there.----Good luck!
Davey Snake!
Oct 24, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq presario 2100 laptop operating system not
On my Compaq Presario Windows 7 laptop, I have got "Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
Oct 10, 2009 | Compaq Presario 1692 Notebook
Error loading operating system
1. The reason it says "error loading operating system" is because kill disk wiped the operating system from off your computer.
2. Now that you have the installation disk, you need to tell the computer to boot from it. For Dells, usually press F12 when the Dell logo appears, and it should bring up a boot menu. Select the optical drive and it should boot. If you do not see a boot menu, go into your computer's BIOS and tell it to look at the optical drive first when booting, then it will boot from the disk.
Jun 28, 2009 | Dell Inspiron 1100 Notebook
Still wont boot
Disk boot failure is usually a sign that your operating system has become corrupt in some way.
If you've got your Windows disc, put that in the CD rom, then boot the computer.
There's a "repair" option that you can select, instead of re-installed Windows.
That *should* fix the problem.
It's also (thought unlikely) possible that your hard drive has died completely.
Mar 19, 2009 | HP Compaq Presario SR1303wm PC Desktop
I have a black screen that says "missing operating system"
while booting press F2 or DEL to enter BIOS...there u can change boot device priority..there u can chenge the 1st boot device as the hard disk...
Nov 30, 2008 | Compaq Presario 700 470024-192 Notebook
Operating system not found
This message means that the hard disk was not detected, this is due to either the BIOS setting was changed or the hard disk has failed.
Try booting up with a DOS disk and run FDISK, and see if it detects the hard drive, if possible run a diag test program.
Nov 22, 2008 | Compaq Presario 700 470024-192 Notebook
Computer on Black Microsoft Corp Page
This will either be an operating system error/glitch or a failed hard drive. You will need to perform a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If the hard drive will not format, or you have any issues during or after the install, then the hard drive has failed and will need replaced.
Aug 29, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq presario 700
your operating system wasn't found because kill disk wipes your hard drive clean.
Boot into the BIOS (tapping the delete key during initial boot-up should get you there, or follow any instructions on the bottom of your POST screen to get into "set-up") and make sure your DVD/CD drive is the first boot option, then put your operating system disc in the drive, and re-boot...the drive should read your CD, and boot from there.
Jun 07, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
159 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
