Question about Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
What size file is use to sharpen the chain on a 34cc 16 inch bar chain
SOURCE:
emissionwiz
  • 85206 Answers
SOURCE: What is the size & pitch of the Wild Thing?
Moto tool makes a set of grinding stone wheels with the 3 common sizes, it is the best set up around and cheap to buy.
Posted on Nov 29, 2008
miket756
  • 2702 Answers
SOURCE: why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Posted on Mar 28, 2010
dontbother10
  • 2220 Answers
SOURCE: I Have a poulan brand chain saw that the bar oiler
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
An example of a Poulan “PP220 Gas Chain Saw Type 5” IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP220-Gas-Chain-Saw-Type-5/75.PP220-Gas-Chain-Saw-Type-5.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for the oil system and is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly.
It has an outboard clutch use this and the IPL as a guide for removal. R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If your saw is not a Type 7 an IPL for all Poulan chainsaws can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 04, 2010
dontbother10
  • 2220 Answers
SOURCE: specs on 4620avx chain
Both questions are answered on page 16 here (if original chain):
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2010/NOUS2010_545186802.pdf
Quite a few of the questions on this page apply to your undertaking.
http://www.oregonchain.com/pro/service/faq.htm
Please take few minutes to read any that may remotely apply. A few minutes spent here may prevent the frustration of a chain that will not cut straight through teh log.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
  • 509 Answers
SOURCE: What size file do i need to sharpen the chain on a
I have the same saw. It takes a 5/32 file.
Posted on May 09, 2010
What size file to sharpen chain?
That all depends on which chain you are running.Typical and most common 3/8 inch chain uses 3/16" file
May 26, 2016 | Garden
Chain file sharpening size
For the normal size chain you use a 5.2mm round file. Smaller chains for top handles take a 4mm round file.
Jan 02, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Help desk number
3/16
Click on the image by CHAIN TYPE to enlarge. All file sizes are shown.
Jun 28, 2013 | Husqvarna Garden
Poulan pro 16 34cc file size
If it is running a standard 3/8 low profile chain then you shoud use a 5/32 round file.
Jan 12, 2013 | Poulan P3416 16Inch 34cc 2Cycle Gas...
What is the file size (to sharpen chain) for a Poulan Pro 295 46cc?
I am pretty sure this machine ran a .325 pitch chain, so the file size is 3/16, if it is running 3/8 low profile chain ( 91 ) it will be a 5/32 file, the pitch should be marked on the bar .
Sep 16, 2011 | Poulan Pro Chain Saw 46cc 20"
Engine starts, runs, chain goes around, but cuts very weak, leaving black marks on the wood from rubbing but not cutting
You have a dull chain. Check out the video below to learn how to hand sharpen the chain:
Thanks for choosing FixYa,
Kelly
Jul 14, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
What size file do i use for a Ryobi chainsaw model PCN4545 to sharpen the chain
The standard chain file should fit it. It is about 3/16 dia. I found the dremel to work 10 times better, they have a little stone bit just for chains. Eventually, you have to take it in for sharpening, it will set all the teeth the same.
Feb 24, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Sharpening Ryobi 4046c - what size file ?
Chain Type File File Profile
1/4” Micro 5/32” (4.0 mm) Round
3/8” Picco Mini 5/32” (4.0 mm) Round
3/8” Picco Micro 5/32” (4.0 mm) Round
.325” Micro, Super 3/16” (4.8 mm) Round
3/8” Micro, Super 13/64” (5.2 mm) Round
3/8” Square Grnd Tapered
.404” Micro, Super 7/32” (5.5 mm) Round
.404” Square Grnd Tapered
Depth Gauge File Flat
Jul 11, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
HUSQVARNA MODEL 50 BAR AND CHAIN UPGRADE
I have a nearly worn out 42 cc Husquvarna that uses a 20 inch bar very successfully. With proper filing of the chain you should be able to run a 22 inch bar very well. Ensure that the roller nose on your new bar matches the pitch of the clutch sprocket that you are using at present. If not, have your chain saw shop change them so they match.
I would advise that you change the bar and sprocket to use a .375 chain as this will be easier to sharpen successfully than the .325 pitch chain you might be presently using.
I am six feet tall and short bars are murder on my back so this is why I use no shorter than 20 inch bars on my saws.
Jan 25, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Logo
165 people viewed this question
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
