Question about Acer Aspire E360 PC Desktop
My Acer E360 is not booting windows. I have vacuum clean the Memory and also the processor and the heat sink which is attached to it. Now the problem is even worse, when i power the system unit, few components like the cooling fans, and the motherboard funtions, however the light that shows on the power button, which usually appears to be blue color and becomes stable is doesn't stay on. I also notice it makes some sound continuosly, which is not normal without even displaying the BIOS. Please, what do you think might be the problem? Thank you
  • Acer Master
  • 7,733 Answers
The clean that you do is not recommended unless you got a very old dusty system.
Processors need a anti-heat cream before installation to prevent over heat. Try change the RAM sticks, if persists, dont spend more, buy a new one.
Posted on Oct 24, 2010
SOURCE:
Windows 7 freezes and mouse changes shape
KAEL, YOU HAVE TO LITTLE MEMORY (RAM) OR TO MANY
PROGRAMS.
Jan 01, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Pc keeps randomly shutting down with no warning
please check the memory and check the processor heat if the processor heats incrreases repidly remove the bottom of the laptop and remove the heatsink and clean the surface and apply thin layer of heat sink compound and fix the processor fan firmly to the socket also check the battery if the battery is old it wont store the power
May 01, 2011 | Acer Computers & Internet
Hi we have an Acer 5536 laptop and after being used for around 25 mins it shuts down. The left front side (hinge corner) gets very hot, is this the position of the processor? Does it need the heat sink...
Please check the heat sink vents. If they are blocked with dust, clean them
You might also need to disassemble the notebook, & re-apply fresh thermal grease between the bottom surface of the heat sink & the upper surface of the processor.
Feb 05, 2011 | Acer Computers & Internet
Pc running but wont recognize screen I have tried other screens but same result ,replaced video card still nothing on screen what else should I do
remove your memory card and wipe it clean with a clean cloth and insert the memory in the slot dont forget to remove all the addon card ide or sata cable power to hard his and cd drive restart the computer see if the display is ok if not remove the processor fan and the processor clean it with clean cloth and fix the processor to the socket also clean the heat sink and apply a thin layer of heat sink solvent and fix the heat sink tightly to the socket if the display doesnt come change your processor which suits the socket
Dec 15, 2010 | ASUS P5GC-MX/1333 Motherboard
Acer veriton M460 will not boot up
The acer veriton m460 has three faulty capacitors. Check and see if you have bulgy capacitors. I have ten of these computers and all have three blown capacitors.
Jul 31, 2009 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
Acer E360 doesn't turn on, only a long beep, nothing on screen.
ok ill tell u wats wrong, one of the hardware needed to start up the computer is damaged... wat you do find out what motherboard is inside and look up the beep sequences and see whats wrong with it.... REMEMBER: the beep means error XD jst look the motherboard up
Jun 14, 2009 | Acer Aspire E360 PC Desktop
SYSTEM DOESN'T BOOT UP, GET LONG STEADY TONE WHEN SYSTEM STARTS
please check the system memory (RAM)
remove them and carefully clean in mouth with a clean A4 white sheet
or change the memory if possible...... and if problem still occur, please check the system processor too...
to check if the processor is functioning, remove the heat sink on the processor and boot the machine placing your finger on the processor chip.
it burns your finger after a short sec. BUT this should be done in a controlled way and after the memory had been tested for
May 10, 2009 | ASUS P4S533-MX Motherboard
Heat on n1996
you may need to clean the heat sink, fan, and the processor.... put some silicon wax between the heat sink and in the processor.. ^^
Jan 30, 2009 | Acer AOpen MX 3ZA (91.88110.101)...
Acer Aspire E360 PC Desktop Logo
97 people viewed this question
Ekse
Alun Cox
