Question about Life Fitness Remanufactured 95Xi Elliptical Crosstrainer Elliptical Trainer
If the lcd screen for the life fitness 95xi is not working, will a new battery fix it?
  • 2,382 Answers
Hi, depending on whether you have a weak battery or not, first of all replace the battery and if the display does not come up then you definitely have a bad lcd screen which needs to be replaced or check out the the wiring connections that attaches to the lcd screen to confirm if it is connected.
If the wire is connected to the lcd screen, you change the battery and the lcd screen does not come up, you have no choice that to replace the lcd screen.
Posted on Oct 23, 2010
  • Tunde Autos
    Tunde Autos Oct 23, 2010
    It should not be more than $60......
SOURCE:
Tip
95Xi Crosstrainer Pedal Replacement
Video about How to Replace the Pedal on a 95Xi Crosstrainer by LifeFitness
  • This video is about how to replace the pedal on a 95Xi LifeFitness crosstrainer
  • Tools necessary:
    • T40 Torx Driver
  • Remove the (4) torx bolts securing the pedal to the pedal lever assembly
  • Install the new pedal in reverse order
  • This completes the replacement of a pedal on the LifeFitness 95Xi
Life Fitness Crosstrainer 95Xi Video Pedal Replacement
on Apr 28, 2014 | Exercise & Fitness
Life Fitness 95xi elliptical electronic panel will turn on but after a few seconds the screen goes blank and evenutally starts back at start up screen.
I would suggest verifying 6 volts output from the battery. From there, check the reed switch connection on the power control board. Also verify the gap between the reed switch and the magnet on the pulley. It needs to be close enough to the magnet to get a good reading. I am attaching a link to a video that shows the reed switch replacement procedure. You can see the magnet and also the slots in the reed switch that allow the adjustment. LifeFitness 95Xi Crosstrainer Video Reed Switch Replacement Speed Sensor
Mar 18, 2014 | Life Fitness 95xi Elliptical Crosstrainer
Electrical issue.
check the battery or alternator that charges it. battery is usually front end and alt is in the back. if this is not it it could be the the controller board
Mar 18, 2014 | Life Fitness 95xi Rear Drive Commercial...
Where is the battery on the life fitness 95xi
The battery is located in the front of the rear drive mechanism. It is mounted just below the alternator control board. The following video shows the battery location along with the battery replacement procedure. Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Dec 29, 2013 | Life Fitness 95xi Elliptical Crosstrainer
Life fitness 95XI elliptical clanks
You may still have the original tie rod design on your machine. If so, more than likely this is your problem. The link below is the updated fix for the original design.
Control Link Kit LifeFitness GK62 00002 0071 SPORTSMITH net
Dec 16, 2013 | Life Fitness 95XI Elliptical Trainer...
THhe life fitness 95XI display does not work - where is the battery located to change
under main shroud 4 screws 2 each side, then allen key to remove and replace.
Sep 21, 2013 | Life Fitness 95xi Elliptical Crosstrainer
How to reaplce a battery on the life fitness 95 xi
u open top rear hood and you will see battery on there
Nov 19, 2010 | Life Fitness Remanufactured 95Xi...
Life Fitness Remanufactured 95Xi Elliptical Crosstrainer Elliptical Trainer Logo
1,063 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Android Man
Android Man
Kenneth Simmons
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
