I need operating instructions for my craig dtv converter box!
SOURCE:
  • 73 Answers
SOURCE: converter boxes
Any brand will do. They dont mention TruTech because it is a OEM brand that Target has had manufactured from many different sources. See here....
http://www.iconnectdots.com/ctd/2007/05/targets_trutech.html
Best regards,
Charles
Posted on Jan 09, 2009
SOURCE: DTV converter Box and Zenith system 3
I have the same problem.... On the back of the tv, there are three coax spots. One is for Cable, one is antenna decoder, and another is a loop. I have had zero luck getting any of those to receive the signal. Instead i have ran my digital signal to a vcr, then ran rca cables from it to my tv. I then put my tv in vcr mode, or aux depending on where you hooked it up. You can watch tv through your vcr this way.
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: Need remote for Magnavox DTV converter box
You can buy a replacement remote for your Magnavox from links on this page :http://www.ezdigitaltv.com/Replacement_Remote_Controls.html They seem to be cheaper than the link above. Good luck!
Posted on Jul 07, 2009
SOURCE: do i need a DTV converter box with this TV?
do I need a converter for a tv LC, if I don't have cable?
Posted on Jan 09, 2010
SOURCE: NEED CODE FOR AN APEX CONVERTER BOX FOR THE RCA
how can i program a rca remote without a code search button to a apex digital converter cable box
Posted on Nov 18, 2010
Need the code for craig convert box Need the code for craig convert box
The code to control your Craig STB would be in a compatible remote control.
Jun 08, 2018 | Craig Televison & Video
What is the code for the Craig digital converter box to access channels
The remote that comes with your converter box will not work with your VCR/DVD recorder. You'll need a seperate universal remote - See more at: http://www.dtvusaforum.com/threads/3309-I-need-help-to-find-the-CODE-for-CRAIG#sthash.60Q0ehJJ.dpuf
Dec 31, 2016 | Craig Televison & Video
I need code for digital stream box for a trinatron tv
Faq - digital stream technology, Inc. ( digital stream ...
www.dsconverter.com/index.php?p=5
Can I use my Universal Remote Control to operate the converter box? ... Do I need a special antenna to receive digital or high-definition TV? .... Note: If you want to reset the remote back to the beginning of the TV code list, clear the memory by ...
Installation - digital stream technology, Inc. ( digital stream ...
dsconverter.com/index.php?p=3
Connecting the DTV Converter Box to your Analog TV Set with RF cable · - Connecting the DTV Converter Box to your Analog TV Set with Audio/Video cable
Digital Stream Analog Pass-through DTV Converter Box
www.amazon.com/Digital-Stream.../B001TO3L8Y
Amazon.com, Inc.
Rating: 3.4 - ‎131 reviews
Digital Stream Converter Box Remote DTX9950 ... RCA DTA-800B1 Digital To Analog Pass-through TV Converter Box ... I think the bad capacitor is something like a 16 Volt capacitor, and you have to replace it with a ... remote(I was able to find the code for my old JC Penny TV), a seperate button for channel signal strength, ...
Amazon.com: Customer Reviews: Digital Stream Analog ...
Amazon.com, Inc.Digital Stream Analog Pass-through DTV Converter Box ... the code for my old JC Penny TV), a seperate button for channel signal strength, ... My brother somehow found out that there have been many of these Digital Stream boxes that were .... button that you can program into your tv (mine is a 1990's 11" Sony Trinitron).
Jan 14, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Unable to receive dtv signal on model CTV1703
It may be that you need to supply a separate dtv converter box to tune in channels...I don't believe the dvd player has a tuner in it
Dec 30, 2010 | Craig 731398407019 Portable DVD Player
DTV Conversion Question
Yes you can connect a DTV converter box in your van.
If the TV is DC powered you will need to buy a DC to AC inverter, like these http://www.dcacpowerinverters.com/12_volt_power_inverters.html because there are currently no dc dtv converters available.
If the tv is ac powered you will only need to connect the converter to the inverter the tv is connected to.
If you need more help or installation instructions let me know.
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Apr 03, 2009 | RCA R52WH73 Projection Television
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
TV Guardian menu won't come up after hooking up DTV converter box
You may want to check the digital converter boxes and make sure they have analog pass through, it should be listed on the box or the instructions. My Magnavox and Zenith which were bought about a year ago, do not have analog pass through.
Feb 23, 2009 | JVC DRMH20 DVD Recorder
Does Toshiba TiVo RS-TX20 accept the digital in February?
Any DTV Converter Box.
You Need a IR cable to control the DTV Box from the Tivo.
Repeat Guided Setup and select the correct DTV Box on the setup.
Jan 03, 2009 | Toshiba RS-TX20
ZENEITH DTT900 ANALOG TO DIGITAL CONVERTER BOX CONNECTIONS
Can't go through the VCR in the normal way. The DTV box must be tuned to the channel you want to record and left there. Cannot tell VCR to tape one channel and watch another nor tape multiple timed and multiple channel shows unless the DTV is tuned to that specific channel. This makes most VSR functions useless.
May 13, 2008 | Televison & Video
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Ekse
