CD and DVD Burners
Problem for CD and DVD Burners
Generic problem for all CD and DVD Burners
NEC DVD+-RW ND-6500A disappeared from
By rverav on Jun 07, 2008
The DVD/CD unit has disappeared from "My PC" menu.
The "device status" says: "Windows loaded correctly the device controler for this hardware, but he can't find the hardware device (Code 41)"
Could you help me?
Thanks
Roberto Vera, from Chile
P.D.: I had to make a translation from spanish to english to explain you the problem. Could be wrong in some parts. I try to do my best.
Clarification Request
Posted by kikoksky on Jun 13, 2008
please try to check this: go to start>control panel>system>hardware>device manager: check under drives: do you see the dvd player listed? try updating the driver of you dvd. what operating system are you using?
Best Solution
posted on Jun 13, 2008
Very Helpful)
kikoksky
Rank: Guru
Rating: 86%, 147 votes
Log on to Windows by using an account that has administrator rights and permissions. Then, follow these steps. Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer this should solve your problem
Was this helpful?
Yes
No
Solution #2
posted on Aug 11, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It works !!
Popular Solutions for CD and DVD Burners
Questions and Unsolved Problems for CD and DVD Burners
Answer
I need an internal cd/dvd burner drive tray where to buy one
Answer
i have a compaq netbook and also an LG gp08 lite super multi drive. when i play regular cd's, the... (More)
Answer
The burner only burns at 4x. I use to burn at 16x a week ago.
Answer
what size supply transformer do i use, what is the input voltage for this unit
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burner Experts
Top Computer & Laptop Repairmen
in , CA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
