Question about Husqvarna Designer I
Wrong hoop display
My machine shows I have attatched the wrong hoop, which I have not. I tried to fool it by taking it off and then on again. It refuses to sew though I sewed this project yesterday with the same hoop and it worked very well. How do I bypass the wrong hoop display?
  • laurenwill Sep 22, 2008
    Machine very hot. The power kept going off and on. Turned off to let it rest and now it is telling me I have the wrong hoop, which I don't. I have this design I just need to finish and I supposedly saved it from the machine to my disk, but its not on the disk. Uggghh.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
If you haven't already done so, download the latest update for the Designer 1 and install it. 2.22 is the latest. Your current software version is in the lower right corner of the display when the machine is first turned on. It only shows for a short time so be ready when you turn it on.
If you have one of the last few versions, the embroidery unit will calibrate by moving the arm to the right and the hoop holder moves away from you, then back part way to the left and the holder will move back toward you and you will then hear a "grunting" sound as the holder moves slightly forward and back to finish verifying its position. If the arm fails to move from side to side or the holder doesn't move forward and back, the embroidery unit may not be fully connected to the machine so turn the machine off, slide the unit 2-3 inches to the left and firmly reconnect it and try again.
You can't bypass the "wrong hoop" display. We just have to convince the machine that you have the correct hoop installed. Let me know how it goes.
Posted on Jun 12, 2008
When trying to embroider on my husqvarna Designer 2 machine, I keep getting the message wrong hoop. I've tried repeatedly to start again, but keep getting the message. What's wrong?
Possibly the hoop is just a tad too small for your design. The hoop needs a certain degree around the edge to move the presser foot. For instance, a hoop that is 5"x7" can only take a design that is perhaps 4.5"x6.5".
Perhaps your machine is not correctly recognizing the hoop.
Apr 18, 2017 | Sewing Machines
When I install embroidery hoop light keeps blinking n saying wrong hoop size looked it up n it's saying malfunction
Ok, there are a couple of possibilities, and I'm going to include an image. I"m not sure whether you're trying to use the small or large hoop, but the first thing you should try is turn off the machine, take the hoop off entirely, then turn on the machine without anything and let it reset to its default position, which will be the center. If it has a problem there, make sure the needle it at its highest position.
Next, put the large hoop on, bring up a design, (preferably a design that came with your machine--there are sample designs in the \Library directory where the program is--that's generally in c:\program files\futuraquartet--and is designed for the hoop you're trying to use, and transmit to machine. If it tells you the hoop is the wrong size, download a patch from www.futura-support.com. If it STILL tells you you have the wrong size, reseat your USB cable into the machine and tape it in place with masking or duct tape.
The third possibility--and the one pictured in the photo I'm going to attach--is there is a tab on your hoop which indicates the hoop size, and your TAB may be off. It needs to be dead center of the sensor, which is also pictured. A while ago a BUNCH of hoops were manufactured with the tabs slightly off, and if it's off, your machine can't read the size. What generally happens there, though, is it will indicate that there is NO hoop attached, rather than the wrong size.
You can see the sensors--they're inside the arm where you put your hoop, and they're not covered up. Below it are the large hoop (top), and small hoop (bottom). The hoop tabs have to match up to the sensors exactly, and you'll be able to see if it doesn't by matching up the notch in the hoop that matches the catch in the embroidery arm.
Oct 20, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
My mega hoop is on, but the screen keeps telling me the color block is not allowed on both sides how do I get it to go???
I have a Designer Diamond, and I experienced the same error message of "color block not allowed on both sides of hoop". I was trying to resume my project a day later, and received this message when I attached the hoop. I made several attempts to fix this problem and get rid of the error message to no avail. Finally I just checked the hoop size on the screen of the machine and noticed it was showing the wrong size hoop attached! I picked the correct size for the hoop I had attached, and viola! - message gone! and I was able to continue on with my project!
Jan 16, 2014 | Husqvarna Designer I
My Singer Futura keeps telling me that I have installed the small hoop and need to change it to the large hoop...but I have actually installed the large hoop. It is giving me an incorrect error message. I...
Make sure you have the latest software version. Current version you may check in About dialog under Help submenu and in the same submenu you wil find a function Live Update.
Also make sure you switch on the sewing machine either with the large hoop connected or without hoop. If sewing machine was switched on with the small hoop attached, it will provide this error message about wrong hoop.
Jan 30, 2010 | Singer CE-200 Quantum Futura Computerized...
The embroidery arm is not working properly. When i try to use the embroidery feature, the arm starts in the wrong area and the machine tries to put the needle through the embroidery hoop. The arm is also...
You definitely need to take that in for service. The machine has a feature that lets it know which hoop is on the machine so is can't sew outside the hoop area, so if it does, you'll need a technician to make it right.
Oct 15, 2009 | Husqvarna Designer I
DISNEY BROTHER SE-270D COMPUTER SEWING & EMBRIODERY
but is the carriage moving,? if not disconnect and try to connect again, the embroidery hoop holder usually moves to check itself, if it still does the same thing the connection that goes onto the machine is not making a proper connection, I also had this problem, with a 2100 brother , I fixed it by using a crochet hook and just tightening the connection that connects to the machine on the embroidery unit, but tread very carefully it just takes a slight move. if this fails it will have to be adjusted cost is usually $100au
Sep 10, 2008 | Brother LS-2125 Mechanical Sewing Machine
Embroidery unit
Do you have a hoop already on when you first re-calibrate the embroidery arm? You need the embroidery arm ONLY when you first turn on. Don't put the hoop on until you are ready to start embroidering. If this is not the problem, try re-loading the machine operating system. If you did not save your floppy or USB file, go to Husqvarna website and download the latest one, and re-load it. (Be sure to select the correct file for your particular machine i.e. floppy or USB.)
Pamsquilt
Aug 10, 2008 | Husqvarna Designer I
Artista 640 embroidery unit
try shutting down the machine and then start up again.try it also with another design as well. But actually i think you may have done something to the timing. take to a bernina dealer for their service rep to handle. also take the piece you were working on and show them the problem
Apr 30, 2008 | Sewing Machines
Sewing Machines Logo
265 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
