Question about GE Ovens
I have a GE Profile range purchased in 2004. Model number is JS968SOF4SS, S/N TG2407460. I was replacing the lens over the light bulb and I grabbed onto the control panel while leaning into the oven. Suddenly the control panel displayed every possible option. I pressed the Clear/Off button to clear the display but instead these codes appeared together: Loc (on left side) and rEF (on right side). I've powered the range off and on at the circuit breaker and also by unplugging the range, waiting at least 30 seconds between off/on sequences. Is there anything I've overlooked? I have scheduled a service call.
  • 2,382 Answers
Hi, you should know that the control panel is the heart of the range that controls every functions that needs to be used and grabbing onto it which i believe is a mistake on you part has prove to be costly.
Since you have done all the necessary things that i would have personally advise (powering off and on at circuit breaker, unplugging the range and pressing of the clear/off button to clear the display) and it did not solve the problem, I believe you have done the right thing by scheduling a service call to come check it out which will definitely identify and solve the problem...
Posted on Oct 23, 2010
SOURCE:
Hi, I have a GE Profile oven that needs a light bulb replacement. It is NOT a standard 40W appliance bulb as stated. What bulb is it?
What is the model number for your oven reply with it and i will give you the GE part number for that light bulb
Sep 17, 2011 | GE Profile JTP18 Electric Single Oven
I just bought a 35 w halogen bulb from lowes for my GE truetemp profile JKP56 built in oven. I just spoke to a GE rep who sells the bulbs and he said the bulb has no replacement numbers so I don't...
If the bulb you bought from Lowes is a 35 watt bulb and it screws in, then it will work just fine.
Appliance parts people love to sell you the "one" specific for your model because most of the time it is more profitable for them.
Good Luck!
Joey
Jun 11, 2011 | GE Profile JKP56 Electric Double Oven
Can you send me step-by-step directions on how to replace a burned out oven light on a Kenmore 30" Electric free standing range, Model#911.92712021, Serial # 2V2 16648Q?
Open the oven door. Grab the light globe and turn it counter-clockwise until it comes off. Next, grab the light bulb, turn it counter-clockwise until it comes out.
Reverse procedures to re-install
Nov 10, 2010 | Ovens
Whirlpool gas range model # GS475LEMS0; Oven light won't come on
If you are sure the bulb you purchased is ok, then I would check the door switch. It is #27 in the attached breakdown, and the part number is: 3196262. Hope this helps. 250
Nov 16, 2009 | Ovens
GE Profile Convection Problem
with GE
SHORTED OVEN SENSOR CIRCUIT
if your comfortable taking the range out of the box, it is a pretty easy repair. The oven sensor is a small tube in the range that "sences" temp.
although it could be the erc, its more than likely the sonsor itself.
it is on the back wall and has to be unplugged from the back to be removed
there are two screws that hold it on the back wall
put the new one in and you should be ready to go
goto appliancepartspros.com
type in your modle number and look in the cavity section
your looking for the oven sensor
they usually run around 20-30 dollars
Oct 17, 2009 | GE Profile 30" Built-In Single Electric...
GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
GE Profile convection with light bulb burning out
Multiple possibilities.
  • Being used as a night lite. (continuous use)
  • Not using a light bulb designed for use in a oven.
  • Inexpensive bulb. (very low lamp hour rating).
  • Oven door slamming.
  • Over voltage condition.
  • (My favorite) Light bulb swapping Gnomes.
Please take the time to give this solution a fix ya rating.
clarkco
Feb 22, 2009 | GE Profile JTP18 Electric Single Oven
GE Profile Convention Light Bulb Not Working after Replacement
With a volt meter you must verify power to the door light switch and the light socket.
You can also unplug the oven and do this with a meter set for continuity.
Feb 17, 2009 | GE Profile JTP18 Electric Single Oven
Need to find Electronic range control part for my GE Range
http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
After you go to this site it is going to ask you to pick your model number it is JTP56XXXX you can located the rest of the model number and from there you can order the part. Or you can just contact them via phone or internet. But you can order the part right offline
Feb 13, 2009 | GE Profile JTP56 Electric Double Oven
Ovens Logo
169 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
