Question about Toshiba Televison & Video
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
I have just a cable cord from the wall (no separate cable box) that is plugged into the back of the TV. The Toshiba VCR/DVD unit is working fine playing but it won't record anything when the TV show is on. The tape shows no signal.
How do I fix this?
    Novelist:
    Champion:
  • 254 Answers
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Posted on Jun 12, 2008
SOURCE:
Toshiba sd-v295 tunerless DVD VCR Combo To Sony Digital TV Instructions
It will depend on if the Toshiba has an HDMI socket. If it has then the Sony TV will almost certanily have one. Then all you need do is get a HDMI lead and connect the two. The only other way would be via a SCART lead. If the TV has only one SCART and it's being used you can get a SCART Switching Box from places such as Amazon, where you will also get the other cables.
Dec 15, 2012 | Toshiba SD-V295 Tunerless DVD VCR Combo...
Since change over to digital dvd/vcr Toshiba SD-37VB does not record on Video tapes. What do I need to do to correct this or do I need to purchase some additional unit?
Subcribe to cable or satellite tv services.Ur dvd/vcr unit will able to be used to record on VHS tapes again.Because cable or satellite tv services the tv incomming broadcasting tv signal still do broadcasting comming in as analog tv signal for the analog devices as analog devices require as it needed.
Apr 27, 2011 | Toshiba SD37VB DVD Player / VCR Combo
Now that we are on digital will the SD-37VB dvd vcr recorder work or do I have to alter a setting to make this happen
If the unit has a built in analogue tuner, the unit itself will still operate as normal, but without the built in analogue channels - to record a TV show, you would need to connect an external set top box to it (SD or HD - or both).
In other words, apart from a separate set top box, if required, there should be no need to change any of the unit's settings if it works as is. I do not believe this model has a built-in digital (DVB) tuner.
Apr 13, 2011 | Toshiba SD37VB DVD Player / VCR Combo
Set clock on sd-kv550-su
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Apr 25, 2010 | Toshiba SD-V295
Need missing owner's manual; cannot find on Toshiba's site
The manual can be found here:
http://www.managemyhome.com/mmh/owner_manuals/search?query=Toshiba+SD-V295KU
Apr 26, 2009 | Toshiba SD-V295
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
Samsung DVD-VR300 - cannot get VCR or DVD to play
cable from wall/outside to cable box in, cable box out to dvd/vcr in ...dvd/vcr out to tv...........set both tv & dvd/vcr to Ch 3.........
note you will not be able to record (probably) HBO on to DVD (vcr yes)
Jan 31, 2009 | Samsung DVD-VR300 DVD Recorder/VCR
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Jan 26, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Televison & Video Logo
275 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
