Question about Video Game Consoles & Games
I recently bought a 22" sylvania tv and trying to hook my ps3 with a hdmi but i see is " resolution mismatch! change device resolution". please tell me what to do to fix this problem.
    New Friend:
I have the same ******* problem hold the button that turns. On your ps3 till it beeps then turn your screen back on
Posted on Feb 09, 2011
  • blakelSimons Feb 09, 2011
    I have the same screen it should work but it will still say that randomly
SOURCE:
How do i correct a resolution mismatch on a 42 inch sylvania tv? I only have the cable box hooked up to the tv and no other electronics are hooked up to it
There is no resolution settings for tv. It's automatically select the resolution from the input device. If you didn't see the picture then you have to set the output resolution of the setopbox.
If you wish to get some details the check the below added link
http://electro-medical.blogspot.com/
May 17, 2016 | Sylvania Televison & Video
My tv says that i have a resolution mismatch and to change the devices resolution but i don't know how to do that.
I've seen this before when using an HDMI connection to a PS3. You need to hook the PS3 up with Red, White, Yellow cables and then access the PS3's display options. You need to match the resolution sizes for both devices. There should only be a few options in this menu so do some trial and error to find the one that looks best :)
Hope that helps!
Jul 18, 2011 | Emerson LC320EM8 32 in. LCD TV
I am trying to hook up my PS3 into my room (Emerson 22 inch flatscreen with HDMI) I am plugging it in with the HDMI cable when it says "Resolution mismatch!" Is that because it was previously on...
This is because your Emerson does not support full HD (unlike your 52").
To fix this:
i) Make sure your PS3 is off (showing red light) ii) Hold down the power button for 5-6 seconds until you've heard two beeps
You should now be able to reset your video options - make sure 1080P is not checked and you should be able to use your PS3 fine with your Emerson.
When you reconnect to your bigger TV, do the same trick with the power button again and turn 1080P back on.
Mar 06, 2011 | Video Game Consoles & Games
How to format so ps3 works
If it's one of the original PS3's you can hold the power button down when you're powering it up until it beeps and then let go of the power button. This will make the PS3 search for what video devices are plugged in. If you're using the HDMI it will say "An available HDMI device was detected. Do you want to output video and audio using HDMI?", and you wan to say YES. Then it will automatically set the resolution (should set to 1080i) and give you 30 seconds to confirm the video works by saying YES again. This TV will not support a 1080p output so if you try to change the PS3 to 1080p resolution it will not work.
Dec 27, 2010 | Sylvania LC320SLX 32 in. LCD TV
FORMAT NOT SUPPORTED FOR PS3
If it's one of the original PS3's (might be the same for the new) you can hold the power button down when you're powering it up until it beeps and then let go of the power button. This will make the PS3 search for what video devices are plugged in. If you're using the HDMI it will say "An available HDMI device was detected. Do you want to output video and audio using HDMI?", and you wan to say YES. Then it will automatically set the resolution (should set to 1080i) and give you 30 seconds to confirm the video works by saying YES again. This TV will not support a 1080p output so if you try to change the PS3 to 1080p resolution it will not work.
Dec 20, 2010 | Sylvania LC320SLX 32 in. LCD TV
Sylvania tv says format not supported when ps3 is plugged into it, just happened use to work fine
I have also received this message when I had a bad HDMI cable.
Nov 29, 2010 | Sylvania LC320SLX 32 in. LCD TV
Hdmi
You need to lower your video source resolution, it is too high for the TV to display. PS3?
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 18, 2010 | Sylvania LC320SS8 32 in. LCD Television
''Please change your computer screen's resolution''
i just bought a philips tv and i have the same problem, have you found a solution?
May 03, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Trying to hook up HDMI to PS3 and the TV keeps saying not a supported format
Try using another AV cable (like a normal composite cable) and try going through your PS3 setup. It may be that it is trying to go to 1080p or something because it is the HDMI, which wouldn't work on yours I bet. See if you can disable the higher resolutions and try the HDMI again to see if you can get the 720p to work. Hope this helps!
Oct 21, 2009 | Sylvania LC195SL9 19 in. LCD TV
Video Game Consoles & Games Logo
1,149 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
