Question about LG Vu CU920 Cellular Phone
Having problems attaching pics to contacts....some of my contacts dont show up on that page....I know its a sim to phone problem but dont know how to fix it
  • 282 Answers
You will have to make sure your contact are saved to your phone in order to attach pictures to contact. Simcard memory does not allow that. There should be a copy all contacts from sim to phone. After that is done then you should be able to attached it as long as the phone has that feature.
Posted on Oct 23, 2010
SOURCE:
My phone show in valid sim card
it could be bad connection between phone and sim card. try using some rubbing alcohol on a q tip and clean the contacts off.
if it still fails . try it in another phone (a friends phone if you dont have a old one). if it works here. the problem is with your phone.
if it still fails you need to replace the sim card.. contact your phone service provider
Nov 25, 2016 | Cell Phones
When receiving calls I dont see the contacts name on screen all it shows is the number calling. Can this problem be solved????
Generally, this is a problem with SIM card. You have to replace and get a new sim card.
Also, contact your service provider if you have caller id service.
May 25, 2011 | Samsung Memoir SGH-T929 Cell Phone
Nokia 6300 Some contact names dont show when receiving texts
try entering the (+) plus sign and the country code then the mobile number / editing the numbers of your contacts. such as, a mobile number alone (depending on the sim) that reads as 09178943874 must be edited as +639178943874 (noting that +63 is the country code).
Apr 26, 2009 | Nokia 6300 Cellular Phone
How do i find numbers that are saved to my sim?????
Most phone have settings to display, only sim contacts or only phone contacts or both
the user manual explains it and it is available in the following link
http://downloadcenter.samsung.com/content/UM/200810/20081030012522500/att_a867_eternity_ug.pdf
Address Book Settings
1. Touch ➔ Address Book Address Book Settings.
2. Touch any of the following options to activate a function:
• My Business Card: attaches a user created virtual business card
as an attachment to outgoing messages.
• Save New Contacts to: defines the destination for new contact
entries (Phone or SIM Card) (page 95).
• View Contacts from: to filter the display of current Address Book
entries. Options include: All, Phone, or SIM Card (page 91).
• Own Number: to display your current phone number (page 93).
• Fixed Dial Contacts: assigns phone numbers as FDN entries
(page 93).
• Used Space: displays the memory storage allocation (total available
and remaining) within both your Phone, SIM card, and FDN list
(page 97).
Hope this helps !!!
Apr 18, 2009 | Samsung Eternity Cell Phone
Insert simcard nokia 7200
hi the only one thing you can try without replacing the sim card reader is do you know when you put the simcard in if you push on the simcard with your finger so your pushing it down onto the contacts is fold up some paper so that it put pressure onto the simcard when you put the battery on as alot of times the contacts dont touch the sim card properly so putting some folded paper on top of sim card pushes it down onto the contacts properly.
This solves the problem in most cases but it can be difficult to get right as if the paper isnt thick enough then it might not push it down hard enough to make contact.
If after doing this it still dont work then this either means the sim cards no good but you could try it in another phone or it could be that the sim card reader is not connecting with the board properly and would need replacing.
Make sure you check the contacts are clean on the sim card and the sim card reader to make sure this isnt problem.
If you have not tried the sim card in a different phone then it could be the sim card is no good.
Did this sim work in the phone before just in case the phone dont accept that network as you can get this message if this is the case.
Let me know how you get on and if you need further assistance ok
Apr 08, 2008 | Nokia N95 Cellular Phone
Phone contacts
well i guess that is how it is
Apr 03, 2008 | LG Shine KE970 Cellular Phone
Memory locked but dont know the code.tried new card but still says not enough memory
These are different types of codes.
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset.
Phone Security Code:
This locks the handset, as opposed to the sim card. Some phones will accept incoming calls with this lock
enabled, but many require the code to be entered even to answer a call. You can also set some handsets to
only accept a "new" sim if the phone security code is entered.
Which is the one that you want?
Not enough memory means your phone is too full of data IE. Pics, Themes, Contacts, Applications, Games etc...
The phone needs a certain amount of memory to function.
Feb 16, 2008 | Cell Phones
Jpeg wont add to contact/2
Make sure that the contact is stored on the phone, and not the sim card.( doesn't work if its on the sim). If you have contacts on the sim and copy them in the phone they double the name, so make sure you choose the phone stored one (there is an icon before the name that shows where that contact is stored). And finally, if still nothing, try to upload .jpg extension file, because the phone resizes the picture to add it to the contact profile, so it might not support .jpeg resizing. Hope you can make it work! :)
Jan 02, 2008 | LG Prada KE850 Cellular Phone
Nokia 1600 ,insert sim and not charging solution
Either your sim card is not seated correctly, the contacts are dirty, the sim card is dead, the copper contacts in the phone do not reach the sim card or the electronics in the phone are faulty. try to change a new battery' or maybe the sim card driver is unsoldered' or need to replace. here is the pics. skilled technician can do. a4f7f33.jpg
Oct 04, 2007 | Nokia 1600 Cellular Phone
LG Vu CU920 Cellular Phone Logo
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
