Question about HP LaserJet 8150 Printer
My hp laserjet 8150n is printing the text too fine and jagged how can i solve this problem?
  • HP Master
  • 7,733 Answers
Go to this LINK.
Posted on Oct 24, 2010
SOURCE:
I have a laser printer 8150n. when i gives 20 print on it. on sheet print after another sheet vacant and third print fourth sheet vacant.. what is the reason
Might be page size mis match> Check paper size in system as well as in printer.> Remove tray &check for paper size.> Clean paper path sensors.
Dec 18, 2011 | HP LaserJet 8150n Printer
We have a HP 8150N. The printer will not print and is giving a 62.0 printer error message. We have turned the printer on and off which has not helped. Is there an eazy fix?
62.0 memory error. This error indicates that the memory that is soldered to the formatter is likely bad. If the error was 62.1 or 62.2 that would indicate that the memory in one of the upgrade slots was bad. The only real solution to 62.0 will be to replace the formatter.
Jun 13, 2011 | HP LaserJet 8150n Printer
Hp laserjet 8150 black blocks lcd display
If the printer isn't intializing then you may have a formatter issue. Try reseating the the formatter in the back of the printer. There is two thumb screws that hold it in place. If the printer is booting up and you can still print to it but you just can't read the control panel then the problem is with the control panel.
May 17, 2010 | HP LaserJet 8150n Printer
Laserjet 2600n .. pale orange strips on pictures only when printing. black text is fine, all cartridges are nearly full. All was fine the day before, no hint of a problem, printing was top-notch. Run the...
on menu take the Service option and then select Cleaning Mode, this must solve your problem, if doesn't, take a look on lasers, they may help to be cleaned.
Aug 07, 2009 | HP Color LaserJet 2600n Printer
50.1 fuser error
Fuser error is the high voltage drum. Normally there is a blown fuse somewhere attached to it that gives the error other you could have a defective fuser unit. Dont attemt yourself it works with very high voltages +- 600V
May 12, 2009 | HP LaserJet 8150n Printer
Manual feed pickup
replaced the manual feed tray separation pad (it is right under the pick-up roller). The HP part # is RG5-2703. First remove the pickup roller then you can pops it out with a small straight slot screw driver.
Jan 23, 2009 | HP LaserJet 8150n Printer
HP 8150N ERROR CODE 79.060E
Power off the printer. Unplug the printer's USB cable for 5 seconds replug turn on the printer. If that fails power off the PC and printer unplug the USB cable at the PC and printer replug and power back on the PC. After PC is fully booted turn the printer back on. If this keeps reoccurring please replace the USB cable and or try different USB ports.
Mar 18, 2008 | Computers & Internet
Settings
Hi, If I'm reading this correctly you want to be able to send a job to the printer and completly print before another job is sent by another user?
Dec 04, 2007 | HP LaserJet 8150n Printer
Print is to one side
is the paper loaded in the drawer correctly(centered)?? if the guides are mis-adjusted thiat could cause this to happen good luck!!
Aug 27, 2006 | HP LaserJet 8150n Printer
HP LaserJet 8150 Printer Logo
53 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
