Question about Intermatic Outdoor Timer/Photo Control HB51RC
HB51R is "on" all the time, regardless of control setting [email protected]
Http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
HB51 appears to be an automatic timer
Capacity is 1000Watts
Your lights are on so the circuit has power
I don't see any troubleshooting steps
It gives you a choice how many hours your lights stay on after dusk
You might try changing the selector to a different stay-on hour.
Turn timer off and unplug and then re-plug timer to see if it re-sets.
Otherwise, it looks like the photocell or 'timer brain' stopped functioning.
Posted on Oct 24, 2010
  • Anonymous Oct 24, 2010
    The manual does not have troubleshooting steps.
    The timer is automatic, which means it turns on automatically.
    If the light is ON all the timer, it says the photoelectric light sensor has failed.
    Or the internal timer chip is not responding to the photoelectric light sensor.
    If you have more than 1000Watts on the timer it will probably overheat and timer will burn out or life-expectancy of timer will be considerably shorter.
    The more watts an electric device carries, the hotter it gets.
    Heat is the enemy of electric devices, and even with less than 1000W, the device can have a shortened lifespan because of heat.
  • Anonymous May 22, 2011
    Pick another timer from following line-up:http://waterheatertimer.org/Woods-timers...
SOURCE:
How do I create an email account
If you have android or a microsoft account (i.e. windows 8+); you already have an email. Android devices setup email at gmail.com. Microsoft sets up email at outlook.com You should also have an email through whomever you pay for internet services through. But regardless you can get email through the two I mentioned. There a many others..
Apr 16, 2014 | hotmail.com Computers & Internet
Hb51r manual
Plug in
make sure bulbs work
rotate dial to set choice of delay times
timer turns on at dusk,,, and delays off for amount of time you choose
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#outdoor
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 13, 2013 | Intermatic Outdoor Timer/Photo Control...
Instructions. for HB51R timer
Check out the HB61RC manual from Intermatic, here. I can't find an HB51R manual, but hese devices look very similar and probably operate the same way. I'll see if I find anything more - and will post it if I do.
If this works - let me know - thanks & good luck!
Nov 28, 2011 | Intermatic Outdoor Timer/Photo Control...
I have an intermatic HB51R. when i go to program it to stay on for a certain amount of time it turns the lights off as soon as i switch it away from the on position. Am i doing something wrong?
I don't think it is supposed to be in the "on" position when setting it up.
Turn dial to "off".
Then plug timer into grounded outlet.
Turn dial to 2, 4, 6 or 8 hours to run after dusk.
Plug in your outdoor lights.
Wait until dusk.
Let us know if this works.
Dec 08, 2010 | Intermatic Outdoor Timer/Photo Control...
My intermatic time HB51R flashes on and off when on the timer position (2,4,6, hours) it keeps the lights lit on the "on" position and "off" on the off position
I think the timer's photoelectric eye is getting too much light from the Load it turns on.
To check this, set timer at 2 hours, and then put black tape over the photoelectric eye so timer senses that it is dark and turns ON.
If timer does not blink with black tape, then problem is too much light with will cause on-off cycling of the timer.
If timer blinks with black tape over the eye, then timer is suspect. Exchange timer for another one.
Dec 05, 2010 | Intermatic Outdoor Timer/Photo Control...
I need a remote for my rca F25648 tv. Can I buy any universal remote?
Regardless o brand, take the time to check the maker's website to see if your model code set is built in to the 'universal' remote; there isn't really any such thing, there are 'multibrand' and 'multidevice' remotes and often, even if a specific model is included, it may only offer the most basic functions.
Your best bet is to bite the bullet and pay for a known original or a tested substitute here:
RCA remote
Oct 13, 2009 | RCA F25648 25" TV
How do I set the hb51r so it turns on and off after 6 hours?
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk unless you set override feature shown below
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
From these instructions, you should push button until 6 displays. Timer will turn ON at dusk and turn OFF 6 hours later
If timer.
If you want timer to turn ON immediately and turn OFF 6 hours later, push button until 6. shows in display.
If timer does not display or does not operate correctly, then timer is suspect. Return timer for another one.
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
Setting
manual for HB51RC
See timer at Amazon
Timer turns on automatically at dusk + override lets timer run during daylight hours
F > Lights are OFF
O > Constant ON
Help me
What Windows are you using? regardless, do not use the set up of windows to create email account if your just going to use hotmail. Go directly to the browser (internet explorer) and do it from there. Hotmail is web base mail account (meaning u need not set it up in your pc) the email that needs setting up is email client like outlook.
Hope that helps
Dec 31, 2008 | Computers & Internet
Intermatic Outdoor Timer/Photo Control HB51RC Logo
609 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Mike
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
