Question about Cameras
I really need help!! I need to download the manual for the sony cybershot 12.1 digital camera. I cannot find it anywhere and I am going crazier than I already am...
SOURCE:
SOURCE: sony cybershot camera DSC-P100 Digital
I don't have a repair manual but I can fix your LCD if you got one. If you don't have LCD, I got one to replace. Let me know what you would like to do. Thanks.
Posted on Jun 09, 2007
YaBaPortugal
  • 123 Answers
SOURCE: How do I download pictures from my Cybershot Sony
Most of those cameras come in PTP mode.
In the camera: Go to the menu, and select USB MASS STORAGE mode.
This will be easier to you, it works like a usb pen drive.
Posted on Sep 15, 2009
  • 8 Answers
SOURCE: i need to download a sony cybershot DSC-S700
you can download the pictures in a very easy way by using a card reader. buy one and take the memory card out of the camera and put it inside the reader.
it has a USB connection and does not need a driver.
Posted on Nov 02, 2009
darntoothysa
  • 489 Answers
SOURCE: SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
Posted on Mar 17, 2010
AdiIngel
  • 87 Answers
SOURCE: Cyber-shot DSC-T70 Digital Camera: My Sony Cybershot dsct70 touch screen vibrates whe...
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Posted on May 26, 2010
How to i charge my digital camera
Take the battery pack out of the camera, insert it into the supplied charger, and plug the charger into a wall outlet. Full instructions are in the "Charging the battery pack" section of the manual (page 12 in my copy). If you need a manual, you can download one from
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCW310
May 15, 2011 | Sony Cybershot DSCW310 Digital Camera
Where can i get a user manual from ? can i down load one off the net if so can i have the web link please
I'd love to help you find your manual, but you didn't specify your model. However, I'll show you how you can find your manual.It's very easy to find manuals online for digital cameras, but you need to know the model of your camera and the brand. For example, if you search up 'Sony Cybershot Manual', there will be WAY too many in the search to narrow it down, however, if you searched up 'Sony Cybershot TX5 Manual' you will be able to find it exactly. You can go to google and search it up, it's really easy.
Cheers!
Mar 29, 2011 | Cameras
I need to replace my manual to cybershot 7.2 mega pixels
There are two Sony Cybershot camera models with 7.2 megapixels, the DSC W120 and the DSC P150. The Sony Product pages for each has many helpful resources including a download of the manual.
Go to the proper Product Page, then click on the "Manuals" tab to access the link to download the manual (see below). It's a .PDF file so you will need Adobe Acrobat Reader. It's a free download available at: http://get.adobe.com/reader/. Don't forget to save the download to your hard drive for future use.
Oct 28, 2010 | Sony Cameras
I need another copy of the full manual Sony DSC w55
hi
you can download the manual at the folowing URL
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSC-W55&region_id=1
happy clicking
pls rate if this was any help
Jul 14, 2009 | Sony DSC-W55 Digital Camera
Manual and software cd for sony cybershot dsc-t700
Hi
Please download the user manual for your Sony Cybershot DSC-T700 from this link
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/DSC-T700-_E
The drivers for your camera could be downloaded from here. Need to select your OS from the pull down menu before downloading
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCT700
That is all you need to connect your camera to your PC.
If you would like to edit your pictures, you need to buy that software
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Cameras
MANUAL SONY CYBERSHOT DSC-S700 CAMERA
here u go pls rate me FIXYA for help
http://www.docs.sony.com/release/DSCS650_EN_ES.pdf
Mar 24, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Sony cybershot dsc p200 user manual
Press Menu and go to setup, set date and time option to adjust it.
You can download user manual of DSC-P200 by clicking Sony Support. for further guidance.
Feb 11, 2009 | Sony Cyber-Shot DSC-P200 Digital Camera
User Manual and Guide for Sony Cyber-Shot DSC-P32
Download User Manual (pdf) of Sony DSC-P32 Cybershot from Sony Support.
Nov 05, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Sony Cybershot 5.1 Pics always coming out blurred?
You can download the manual from the link below: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCS650&LOC=3 Try initialising the camera back to the factory settings. This is on Page 21 of the manual. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 20, 2007 | Sony Cybershot S650 Digital Camera
Cameras Logo
29 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
