Question about Xitel INport (HFLI1X1) Audio Input
Xitel INport requires a password. Used this devise years ago and forgot the password. How do I get the password so I can install the LP recorder?
  • 7,733 Answers
Posted on Oct 24, 2010
SOURCE:
I now have a windows 8 how can I get it to work?
Have a look at the original instructions to see which operating system the software will work with. It should also tell you on the installation disc. If it doesn't mention Windows 8 you might have a problem. You can also visit the Microsoft website to see if your version will work with Windows 8. Or go to the help screen on windows and type "software won't run in windows 8".
You can also visit the software makers website to see if they have a solution.
Jan 29, 2014 | Xitel INport Deluxe for PC
LP recorder incompatibility
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Dec 19, 2013 | Xitel INport Deluxe for PC
0047BB69 with the LP Recorder
This is not a solution. i have just discovered that I have exactly the same problem.
Nov 06, 2013 | Xitel INport (HFLI1X1) Audio Input
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
Need s registration key for xitel inport to put on my computer
I bought my'n from the home shopping channerl for $89.00
works excellent.
Feb 06, 2010 | Xitel INport (HFLI1X1) Audio Input
INPORT Installed, Sound Disappears
The Xitel site http://www.xitel.com/USA/support_inport.htm says when this happens, " 1. Go to START -> CONTROL PANEL -> SOUNDS AND MULTIMEDIA PROPERTIES -> AUDIO TAB
2. Make sure that in the Audio tab your soundcard appears as the Preferred Playback device with USB Audio or INport as the Preferred Recording Device. There should also be a check next to the option 'use only preferred device'.
3. When you start LPRecorder you should also make sure that Recording Device is set to USB Device or INport and Playback Device is set as your soundcard and that there is a check next to the option Simultaneous Playback."
Jul 20, 2008 | Xitel INport (HFLI1X1) Audio Input
Xitel INport (HFLI1X1) Audio Input Logo
342 people viewed this question
Top Xitel Televison & Video Experts
Ekse
Are you a Xitel Televison and Video Expert? Answer questions, earn points and help others
