Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Had a sears tech come out, paid 100 tx to confirm the obvious, ie, main brg shot and $500-600 to repair. apparently everything comes as a kit these days. never had any error code problems that others seem to have. mdel # 45872 unit 4 yrs old question... is it worth getting fixed?
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: F-5 error code on Kenmore elite HE3 45872
Click on the following link for a full explanation of the "F05" error code:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
This is not a difficult repair. The error indicates a failure of the heating circuit. If you are not sure of how to diagnose this yourself, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Posted on Jun 12, 2008
SOURCE: Dryer Squeals
my sears kenmore 417 stacking get things caught every time in the dryer and leaves some brown stuff on all my clothes.
How can I keep things from getting caught??
Posted on Jul 20, 2008
  • 126 Answers
SOURCE: F1 Error Codes
sorry to be the bearer of bad news, but its the machine/motor control unit (circuit board). if you don't want to involve sears to get them to pay a portion of the bill, then go to searspartsonline and order one yourself. you'll need your model number to get the right part number ECU (which should be W10189966 rev A) which will run you about $150. replacing it is relatively easy is you're handy at home. sears service will charge you another $130 to install it. this will fix the F1 problem.
not sure if sears has finally recalled this washer. if they finally do, then all our problems go away (yeah, right).
Posted on Jan 28, 2009
  • 3 Answers
SOURCE: F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Posted on Feb 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: My washmachine is less than 2 yrs old and has stopped working.
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
Well my dishwasher won't turn on and it keeps blinking clean and I cleaned it and it won't work
1st unplug or dispower appliance for 2 min. Then, be sure door is cloesd, press heated dry key and Hitemp repeatedly until all lights on panel light up; if no....
The clean led blinks 7 times which indicates a heat circuit error.
Pull the kick plate off and behind should be a tech sheet..Look for heat cicuit... Check the heater for continuity..Some models come with kits main erc w heater....If heater test good then replace main erc and neutral line door switch located inside panel w main erc... Estimate for tech to repair $249-$329.... If you follow my directions you may soon one day become a tech..... A good tech would make $100-$150 on this job profit
Oct 29, 2012 | Dishwashers
I am looking to convert my kenmore 970-c92062 ng dryer to lp.
The supplier of the LP gas can supply the needed parts for conversion.
Aug 09, 2017 | Amana Dryers
Standby mode 7 red brinks Check with sears ,estimate $218.00 board replacement, Tech charge $105.00 to tell me whats wrong, labor extra. Chucks repair estiment $400.00 . I have repaired TVs years ago....
turn (only by 2 degrees ) all the knobs on flyback transformer in clockwise direction & then switch on tv .............you will get picture atleast for 1 or 2 mins ............ this confirms only flyback transformer is defective ........ so it has to be replaced by new one .................otherwise transistor (big in size fixed near flyback with its back clamped or screewed to aluminium metal ) has to be checked ......if that is also fine then complete main board has to be checked ...... but flyback replacement is a must ........in your case iam 100 % sure only flyback is deffective ...........vishnuswamy_22.jpg
Aug 24, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Onkyo - mainboard issue
Unless you hear the speaker relay click about 6 seconds after powering on.
Chances are it needs output transistors and a few resistors. $100 is a fair price. they are not the most tech friendly things to work on ( no removable bottom panel ) you must remove everything except the front panel and power transformer to access the bottom.
Oct 15, 2009 | Onkyo TX-SR605 Receiver
How to put on new line segments onto wheeled weed trimmer
If is a sears product go to sears parts .com they will answer your question.
Jul 04, 2017 | Craftsman Garden
2005 toyota solara convertible rear window defroster
2006 Solara Comvertible - same problem as everyone else. The defroster just stopped working (well, 2 lines in the upper portion work somewhat) several months back. The light comes on and obviously power is there since 2 of the lines do something. The dealer also told me the WHOLE top would have to be replaced...thousands of dollars. I thought I might have to replace the window but apparently that can't even be done. They actually told me a repair kit exists to do it yourself at Pep Boys, yet they won't attempt to fix. Pep Boys confirmed kit exists but won't tounch it either, Window replacement company won't either. So, again the consumer is screwed, I guess. Obviously if those paid to do mechanical work can't or won't do it, why would a novice be able to? I am so angry! No more Toyotas for me. My buying experience was a whole other story that turned me off from this car to start with. Probably when someone gets killed, they will be forced to look at this. Convertibles are notorious for poor visibility in the rear and now with the windshield completely frosted or covered with snow and iced while driving due to the weather conditions, it is UNSAFE! Is there any help for this problem?
Dec 03, 2008 | 2005 Toyota Camry Solara
Gas smell when start oven
Hello, Kimquy25 -
Fixya.com is not a website for scheduling a Sears technician to inspect your gas stove.
Since you live in Houston, Texas, see the information here:
https://www.searshomeservices.com/locations/appliance-repair/tx-houston/4201-main-st
Personal opinion: If you can avoid it, do not use your gas stove / oven until a repair person checks it. Also, if you think there is a gas leak, IMMEDIATELY LEAVE YOUR HOME, go to a safe location and call the CenterPoint Energy natural gas Leak Emergency Hotline: 888-876-5786. - See more at: http://www.centerpointenergy.com/en-us/residential/customer-service/reporting?sa=LA#sthash.fGZo7JXh.dpuf
Best wishes.
Dec 19, 2017 | Stoves 720EF Electric Double Oven
Toshiba 53H71
omg.. i have the exact same prob...
is it a conindenice that we are all having the SAME prob around the same time?
Jun 22, 2008 | Toshiba 53H71 53 in. Rear Projection...
Black Screen - Haier 42EP24S 42 in. EDTV-Ready Plasma Television
Mine did the same thing, I called Haier and reprted the problem. there is some kind of kit to remedy the problem where 3 boards are replaced. The repair performed by Sears service center was in home and cost me nothing for parts or a sevice call. Sadly now the monitor is working agin but with some interference of some kind. I called Sears service and they are coming back.
Sep 28, 2006 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
