Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
It will run good on half choke but dies when it is put on run
    New Friend:
  • 3 Answers
You will need to a Poulan Tool and Adjust the Carb. There will be 2 round nobs on the top of the Carb. You can get those tools at any Lawnmower Repair shop for a few buck. Be sure to Take your machine in and show the guy because there are different nobs on different Carbs. If you own a Poulan you will need it all the time anyway. LOL Good Luck!!
Posted on Nov 04, 2010
SOURCE:
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
Put choke to run it pops put choke half way runs good
dirt or water in carburetor.Choke helps suck more gas in engine to run better.
Dec 28, 2013 | Garden
Engine will start but only run at choke or half choke and low throttle sputteres and or dies if you try to increase to full throttle and dies if you take off choke
Check fuel pump delivery for adequate flow. If when choke enrichment is applied and it runs, then dies when choke is off, fuel flow is inadequate and needs choke enrichment to compensate. Also, if engine dies or chokes when increasing rpms, this will be a symptom of too little fuel. Check fuel flow at pump, then, if flow is good, check for carb blockage, unscrew the jet and inspect, check the operation of the solenoid at the bottom of the bowl, it has a wire attached to it. Trace that wire to where it plugs in, unplug it and touch it to the positive pole of the battery, it should retract. If not you need a new solenoid that has the job of metering in gas to the inner bowl below the jet assembly.
Feb 10, 2011 | V-Twin Horizontal OHV Engine with Electric...
Sounds like fuel starvation. Check for plugged fuel filter or sediment or dirt in the fuel tank. Failing that, examine the carburetor for dirt/sedment plugging it. Good luck!
Oct 14, 2010 | V-Twin Horizontal OHV Engine with Electric...
My 26cc blower starts up and after I put it on half choke or full choke it dies
Do a carb rebuild and cleaning. Check out this website it will show you how to do it smalleng.com awesome site. Good Luck! Don't forget the thumbs...
Aug 13, 2010 | Homelite Garden
I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Shindaiwa Blower - when throttle pushed, engine sounds flooded and it dies. any thoughts on how to fix?
Its not flooded- its lean.
Heres a way to test me. Try to give it throttle but keep it running. At the same time slowly close the choke. does it run better as you close the choke? Does it run pretty good on half choke?
Rebuild the carb, replace the fuel lines and fuel filter.
Dec 20, 2009 | Garden
It starts but in choke and when i turn it to start it turns off
Try keeping it at half choke for long enough time to completely warm up. Once you have warmed it up, put it on "run". If it still dies out, get back to FIXYA. Good luck...Lee
Nov 24, 2009 | Craftsman 25cc Gas Line Trimmer
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
445 people viewed this question
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
