Question about ViewSonic VA1912wb Monitor
I have absolutely nothing on the screen, but i have a blinking green power button indicator that i can't turn off help!!
  • 1,684 Answers
The problem you are having in most likely caused by a failure in the power supply board. Parts called capacitors fail due to heat buildup in the monitor case and will bulge their tops and cause a short in the power supply board. When this happens you get the pulsing power light and no display on the screen. If you can solder then you should be able to do the repair yourself. We have the parts and repair information available at: http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=90 We also offer a repair service if you are interested, details can be found at: http://www.ccl-la.com/blog/index.php/service-request-form/ The repair on your model LCD runs $30 plus return shipping.
I hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Posted on Oct 24, 2010
SOURCE:
Pentax Optio E20 will not turn on.
The green light only means the memory card is getting power. That nothing else comes on indicates a serious problem that requires a trip to your local camera shop for help.
Nov 09, 2014 | Pentax Optio Cameras
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
Sharp LC40LE600E wont turn on
Had exact same symptoms as Keran. Turned out to be my daughter had turned the TV off with the other power switch which is a button on the right hand side of the set - we always use the rocker switch on the left hand side and had forgotten about the button. Turned the rocker switch on, then the button and it was back to normal.
Jul 19, 2012 | Sharp Televison & Video
When I turn on my Canon i560 printer the light blinks orange and green and will not print anything. I've tried to turn it off and on, unplug it and nothing seems to be working. What can I do to fix it?
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Canon BubbleJet i560 InkJet Printer
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
RESETING THE FULL ABSORBER
Waist reset code
1) With the printer turned off, hold down the RESUME button and press the POWER
button (the green indicator lights and the desired service function can be selected).
2) While holding down POWER button, let go of the RESUME button and then press the
RESUME button twice in succession. Then let go of the RESUME button and POWER
button.
(Each time you press the RESUME button, the indicator's color toggles between orange
and green.)
3) During printer initialization, the green indicator blinks. When the green indicator
stops blinking and remains on, press the RESUME button the stipulated number of
times to execute the desired service function listed below.
press 4 times indicator light should be green, this Clears the waste-ink counter.
4) After selecting the service function, press the POWER button. The green indicator
lights and the service function will be executed.
(After the respective function is executed, the printer returns to the service function
selection mode.)
To cancel printing after it begins, press the POWER button.
The Power lamp will blink for a while and then stay lit. You can then select
another service function.
Oct 22, 2009 | Canon Office Equipment & Supplies
Black Screen
The blinking green power indicator means the unit is trying to startup but failing. You can try replacing filter caps in the low voltage power supply.
Dec 30, 2017 | Hannspree HC-194D 19" LCD Monitor
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Canon Pixma Printer trouble
hi dear
try with this metode
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
oke try to print
thanks
cropp
Mar 17, 2008 | Canon PIXMA iP1600 Printer
ViewSonic VA1912wb Monitor Logo
394 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
