Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Lift master model # 101 241A date OCT 1995. house
Lift master model # 101 241A date OCT 1995. house control works fine. remote control malfunctions
    President:
  • 3,197 Answers
Don't know what malfunction means.
Posted on Oct 25, 2010
SOURCE:
I have a new house with a lift master opener. The hand held remotes all work but the wall opener wont. It lights up but wont open or close the door.
If the remotes will operate the auto door lift, then the probable cause is either the switch on the manual panel is bad or the connection to that panel isn't hooked up properly to the main control board. I'd claim on the warranty and/or get the original installer back in to look at it as opening it will more than likely void any claim you may have against it for a manufacturing defect.
Sep 13, 2018 | Building Materials
Lift master remote not working
It seems that the reciever part is defective, likely to surge or lighting, you have to have that module replaced.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Apr 16, 2014 | Master Heaters Lift-master Sears Craftsman...
Purchased a house in short sale with a lift master 1/2 hp model #1155-4 date 11/92. We got a new car remote, it works fine, but don't know how to program the wireless keypad. It is not hard wired and has...
Sorry that keypad is no used to u.If u don't know the secret codes.Just push in the codes it will work.No enter button,mean u just don't push enter after u push in the codes.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
My access Master 350 will not open or close when using remotes
If the light in the wall control is flashing your opener is in the lock/vacation mode. Press and hold the button with the lock icon for 3 seconds. If this is not the case your logic board is bad.
Jul 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: I need a remote for a Lift Master Professional ...
The model number will be on the opposite end of where you found the part number you listed. You can then call any Liftmaster dealer listed in your yellow pages.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a chamberlain 953CD New will it work for a Lift-master ?
You may need a C943 as the + can make the siginal different.[Chambelain or Merlin]
Apr 03, 2010 | Chamberlain 3Button Remote Control Model...
Lift-master 2000SDR remotes will open but not close garage door. Same problem with all clickers and even those programmed into the cars. What could this be and better yet, how do I fix it?
Lift-Master 2000SDR opener. Opener generally works fine from the remotes. However, first time in the morning in cooler weather, it will start to close and the reverse and the lights blink. I have checked the senors - appear to be aligned properly. I have lubed the gear and used garage door spray on the rollers and hinges at the proper places. To close the door when this happens, I have to hold the wall button.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hello!!! I am having trouble. This has happened one time before and I fixd it but I cant remember how in the heck I did it. Here is the prob...The doors will not lock or unlock by the buttons or the...
check the fuses to the CSM ( Central Security Module ) .
CJB ( aka Central Junction Box, cab fuse panel ) Fuse # 15 & 29
15 is the BPP ( Brake Pedal Position ) Switch, so that should be fine, unless you cannot get the truck out of park while running and the brake lamps don't work.
29 is the fuse to the CSM ( hot in start or run key positions ).
BJB ( aka Battery Junction Box, Engine Compartment fuse panel ) Fuse # 115 or 8. 115 is for the Supercrew body style and 8 is for the standard cab & SuperCab configuration.
This is for a build date after 2-OCT-2000 ( 2001 MY ).
Build date before 2-OCT-2000, the CSM is a RAP ( Remote Anti-theft Personality ), looks the same, same functions, but is not pin for pin compatible.
Fuses for this are CJB Fuse #8 and 15 and BJB Fuse #4.
With the CSM / RAP installed, the power door locks are controlled by the CSM/RAP, without the RKE ( Remote Keyless Entry ) installed, they are normal power door locks ( switch to the door lock direct ).
Worth a start checking the CSM / RAP fuse
Nov 18, 2009 | 2001 Ford F150 Styleside SuperCrew
Programming car remote using garage door opener remote control fo
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Jul 03, 2009 | 2003 Lexus ES 300
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,272 people viewed this question
Top Sears Building Materials Experts
Mike
Steve Allison
Steve Allison
Are you a Sears Building Material Expert? Answer questions, earn points and help others
